C5 ABS and Traction Control error messages
Oil sending Unit
steering wheel position sensor
water pump
harmonic balancer
Valve cover gaskets
Upper and lower oil pan gaskets
rear main seal
valley pan gasket
2 power steering hoses
All 4 stabilizer end links
hvac dimming issue
front air dam
updated radiator cap
hvac actuator issue repaired
both window regulators replaced
both headlight gears
EBCM (currently out for repair)
for yours with c1214 being the only current code you can try to open up the ebcm and resolder the 5 tabs on the relay.lots of people have fixed theirs that way. https://www.corvetteforum.com/forums...r-fleabay.html
with all the door control module codes it could be possible you have a connector issue at the door harness.i think i read that a bad harness connection could throw the abs codes.hopefully Bill Curlee will see your thread and chime in. he knows more about the electrical system than almost everyone else here combined.
best thing is to clear all codes and drive for a little and see what comes back.
my guess is it's probably the ebcm causing the code but you did have an ignition fault code so it's possible its the ignition switch.if you clear the codes and they come back only at start up it's probably the ignition switch if the codes come on while driving it's probably ebcm issue.
on my 2002 i was only getting service traction about every 8th-10th startup but it never came on while driving i changed my ignition switch and never had a problem after
on mine i would get service tc/ah every few startups and it was always code p1571 , c1277, b0432, and u1040
pulled out the switch and it was significantly burnt.after i replaced it all was good.
that's why i say if you are getting codes only at startup it's probably a bad battery or ignition switch
