Transmission whoops
Old Apr 4, 2019 | 07:20 PM
wcsinx's Avatar
wcsinx
Originally Posted by lionelhutz
As I wrote way back, the sliders don't generally move on their own. If you've been inside a transmission, then you'd know how they take a decent force to get them to move off center or out of the neutral position. So, I still don't believe reverse tried to engage. It's more likely a piece came loose and went through one or more of the gear sets.
It does ... no argument there. I've seen broken (or even just sloppy) linkages develop enough momentum to move them off center however.
For the record, I've been inside a T56. Even got a bunch of parts in a bin in the basement. I've got the proof of what the gears look like after a piece of metal gets loose inside one. Hope you still fell smug about that comment though.
Did you not read my edit? I already admitted I misspoke early in the thread. You were right, I was wrong.
Old Apr 4, 2019 | 08:46 PM
voda1's Avatar
voda1
The T56 has a double detent system. The keys/springs for the synchro hubs and the detent guide plate uses a ball and spring.
