Axle Ratios
Old Nov 3, 2002 | 11:02 PM
Toecutter's Avatar
Toecutter
Default Axle Ratios
I just bought a 2000 auto.
How can I tell the axel ratio?
It doesnt seem as quick as my m6 TA.
Is there somewhere I can check on the vin?
Old Nov 3, 2002 | 11:47 PM
Crash99's Avatar
Crash99
Default Re: Axle Ratios (Toecutter)
Assuming it's stock:
Look inside your glovebox at the list of codes. If you see G90 then you have 2.73; if you see G92 then you have the 3.15.
If you can't find the code then put the car in 3rd gear on the highway at 75 mph. Take the tach reading and divide by 1000:
3150 rpm = 3.15
2730 rpm = 2.73
Crash...
And let me be the first to welcome you the the Forum. You'll love it here, but be forewarned: mod fever is rampant around here and it's highly contagious. :cheers:
[Modified by Crash99, 7:49 PM 11/3/2002]
Old Nov 3, 2002 | 11:55 PM
Toecutter's Avatar
Toecutter
Default Re: Axle Ratios (Crash99)
Thanks for the reply and welcome!
I think Ill try the highway method first, its more fun while the car is still new to me.
As far as modding Ill leave that for the TA, Ok maybe a nitrous kit!
Old Nov 4, 2002 | 11:06 AM
Mike Mercury's Avatar
Mike Mercury
determine your C5's real axle ratio
[Modified by Mike Mercury, 10:06 AM 11/4/2002]
Old Nov 4, 2002 | 03:23 PM
HOTSOSS's Avatar
HOTSOSS
Default Re: Axle Ratios (Mike Mercury)
On A4 cars in drive, with the 2.73, 2000 RPM's is 80 mph. On 3.15 cars, 2000 RPM's is 70 mph.
To Axle Ratios
