HUD Getting dim
Old Apr 6, 2019 | 07:52 PM
ncali's Avatar
ncali
Default HUD Getting dim
Has anyone had a problem with the HUD dimming over time. I think ,but I am not sure, that I used to be able to see it
during daylight hours much better than I can now. It shows at night just fine and it is not because the dimmer switch is turned down
Just curious if any one else has had this happen
Old Apr 6, 2019 | 08:07 PM
STRMLNE's Avatar
STRMLNE
could be just from sun glare
Old Apr 6, 2019 | 09:21 PM
oh1vette's Avatar
oh1vette
Try changing the angle...
Old Apr 6, 2019 | 09:37 PM
STRMLNE's Avatar
STRMLNE
exactly. A lot of times I can’t see it at all but it’s just from the glare. Sometimes the angle helps.
Old Apr 6, 2019 | 10:05 PM
ncali's Avatar
ncali
Thanks, I will try that. Now that I have a HUD I would miss it if it faded away
Old Apr 9, 2019 | 12:55 PM
mrlmd's Avatar
mrlmd
Mine got dim over time and then it went totally out. I haven't removed the dash yet to get it out but it may be a problem with the photo resistor that controls the brightness in the sunshine.
And also, are you wearing polaroid sunglasses? That can dim the display a lot.
Old Apr 9, 2019 | 04:34 PM
Leftlane_1's Avatar
Leftlane_1
Mine has also dimmed over the years.
Old Jul 3, 2023 | 06:24 PM
sboblett's Avatar
sboblett
How old are you? Mine has gotten dimmer as I get older.
Old Jul 3, 2023 | 06:28 PM
cdw's Avatar
cdw
mine was dim so i removed it and resoldered about eight resistors. there are a few you-tube and tec videos on how to do this. was not hard. don't have to remove the dash.
Old Jul 4, 2023 | 10:27 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
That would be worth a "how to" post. This is genius.
Old Jul 5, 2023 | 09:11 AM
cdw's Avatar
cdw
there are several "how to" post on the web. thats where i got mine. there are a couple different resistor mounting locations there. there are 8 of them i think. small soldering iron and take your time.
Old Jul 7, 2023 | 09:19 AM
grinder11's Avatar
grinder11
Hmmm....8 resistors......Are you confusing the climate control with the HUD?
Old Jul 7, 2023 | 10:39 AM
cdw's Avatar
cdw
yes you are correct. got them mixed up.
Old Jul 7, 2023 | 11:01 AM
grinder11's Avatar
grinder11
No worries. Just making sure.....
To HUD Getting dim
