C5 install prop shaft
Old Apr 7, 2019 | 03:00 PM
jdcorvette02's Avatar
jdcorvette02
4th Gear
Default C5 install prop shaft
On my 2002 c5, I’m trying to install the torque tube after a rebuild and I’m having a problem getting the prop shaft to go fully into the splined opening on the fly wheel. I can get it started, but I cannot get it to go in the last 2 inches. Any suggestions on how to get it to go all the way in ?
Old Apr 7, 2019 | 04:28 PM
StingrayRebel's Avatar
StingrayRebel
Old Apr 7, 2019 | 05:49 PM
jdcorvette02
4th Gear
Thanks for the response. I should have mentioned that I have an automatic trans.
Old Apr 8, 2019 | 07:30 AM
Simtech's Avatar
Simtech
Check to make sure there is nothing caught between the TT housing and the engine on the top. I almost got the wiring harness caught when I did mine but it was much closer. Good Luck.
Old Apr 8, 2019 | 02:02 PM
jdcorvette02
4th Gear
Thanks, I'll check for for an obstruction. How much force is required to get it in ? Should it slide in easily, or did you have push hard from the back of the transaxle ?
Old Apr 8, 2019 | 02:17 PM
Simtech's Avatar
Simtech
From what I remember it wasn't that hard. Can you tell I the splines are lined up you might need to turn the shaft slightly to get them aligned. You also want to make sure the angle is correct and then it should slide in.
Old Apr 9, 2019 | 03:12 PM
vettenuts's Avatar
vettenuts
I would need to pull my service manual but from feeble memory I thought the auto had something that required loosening until all was set in place. If someone doesn't respond I will look for it.
Old Apr 16, 2019 | 08:55 PM
jdcorvette02
4th Gear
I was able to get the TT installed after playing with the angle and applying assembly lube to the splines
To C5 install prop shaft
