steering speed sensor
Old Apr 11, 2019 | 11:40 PM
EZD421's Avatar
EZD421
2nd Gear
Default steering speed sensor
I keep getting a tcm 1287 code which says its the steering speed sensor located on the steering column...Seems like a hard job that takes hours to do, and I was wondering if I could get that message cleared if I unplug the old sensor and leave it where it is, then just plug in a new sensor and zip tie it up under the dash... Long shot but I thought I'd ask and maybe just try that...? My Vette is a 2003 C5
Old Apr 11, 2019 | 11:54 PM
STRMLNE's Avatar
STRMLNE
i don’t think that will work. Some people have had luck with playing with the connector a little to see if it makes a better connection. But most likely the sensor needs to be replaced. Just had mine replaced. Was $500.
Old Apr 12, 2019 | 12:00 AM
EZD421's Avatar
EZD421
2nd Gear
Expensive, or a afternoon under the dash... I really don't want to spend the money, on the hand I don't want to screw something else up..
Old Apr 12, 2019 | 12:17 AM
STRMLNE's Avatar
STRMLNE
I lived with the dash light for a while. But the sudden steering jerks while driving finally freaked me out enough that I spent the money to get it fixed
Old Apr 12, 2019 | 12:22 AM
STRMLNE's Avatar
STRMLNE
I lived with the dash light for a while. But the sudden steering jerks while driving finally freaked me out enough that I spent the money to get it fixed.
Old Apr 12, 2019 | 05:55 AM
Grandpa1's Avatar
Grandpa1
Yep! Either spend the money or do it yourself.
It is quite a job but there are quite a few DIY posts about swapping out the SWPS.
I had mine done because it was too hard on me being old. Costs around 500 bucks.
Good luck!
Old Apr 12, 2019 | 11:30 AM
Steeldragon's Avatar
Steeldragon
I've read posts that said get a good shot of electrical contact cleaner inside the swps and turning the steering wheel lock to lock several times will bring the sensor back to life again.
Old Apr 15, 2019 | 09:10 AM
GS2003's Avatar
GS2003
8th Gear
Hi Grandpa1,
My 2003 50th Anniversary Ragtop is doing the same thing and error code is also Code C1287 H.
Did you take your C5 to the dealer or some other garage? This is most definitely a big job. My concern is messing something else up.
Thanks much!
Old Apr 15, 2019 | 09:12 AM
GS2003's Avatar
GS2003
8th Gear
Hi STRMLNE,
How much did it set you back?
Thanks much!
Old Apr 15, 2019 | 12:10 PM
STRMLNE's Avatar
STRMLNE
My 1287 steering sensor was about $500-600. Not cheap. I did take it to the dealer. A lot of people on this forum stay far far away from dealers. Haha. But, mine is close to my house and while I do pay a little more, they’ve always done a good job for me and if you ask they almost always will give you 15% off. Some people on here have had luck fiddling with the sensor, tightening battery terminals, and or cleaning grounds. None of that worked for me and the jerking while steering is pretty scary. Haha. I bit the bullet and had someone fix it. That job is too big for me to do it myself. 1287 and ebcm 1214 are almost guaranteed to happen sooner or later. Just part of owning the car. Good luck!
Old Apr 15, 2019 | 12:23 PM
Mr. Jones's Avatar
Mr. Jones
I did this and is been fine for two years
Old Apr 15, 2019 | 02:19 PM
Grandpa1's Avatar
Grandpa1
Originally Posted by GS2003
Hi Grandpa1,
Thanks much!
There is a local mechanic that does Corvette work. He has a great rep and I used him. Dealer wanted almost 700 for labor and wasn't really sure how to do it.
I bought the part online from GMPartshouse.
I have the service manuals and did a lot of research on doing it myself but I'm just not young and limber anymore.
To steering speed sensor
