Driver Door Lock Actuator
Old Apr 16, 2019 | 02:02 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Driver Door Lock Actuator
This is brand new on my 99.
As of yesterday, when I click the fob or the door lock control button, the driver door lock WILL cycle closed, but will NOT cycle open and must be manually unlocked. I see that it is attempting to, but it either is not executing sufficient force or the handle may be stuck.
Does anyone have experience with this? Quick fix, or a replacement part number?
Odd that it works in one direction but not the other.
Old Apr 16, 2019 | 03:32 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Some info on the subject from another Forum member:
File Type: pdf
Old Apr 16, 2019 | 03:05 PM
Kimko's Avatar
Kimko
Cruising
Default Door lock actuator
Have the same problem on my 01. Chevy parts said they only sell complete latch assembly, $350.00 even tho the actuator is a separate unit. The actuator appears to be used on all GM cars of the same year and you can find them for sale online but they don't have the anti theft part with them. Maybe some other member has more info on this problem.
Old Apr 16, 2019 | 05:49 PM
Moved to C5 Tech.
Old Apr 16, 2019 | 06:23 PM
Jackie N's Avatar
Jackie N
Have same issue on my passenger side. It'll lock with the FOB but won't unlock.
Old Apr 16, 2019 | 06:38 PM
Kimko's Avatar
Kimko
Cruising
The door lock actuator can be purchased for as little as $20.00 online or at auto parts store. But I have not found a solution for the anti theft part.
Old Apr 16, 2019 | 11:08 PM
Tusc's Avatar
Tusc
What is the anti-theft part? In all my years I have never worked on this part of a car before. Go figure.
Old Apr 17, 2019 | 07:56 AM
Kimko's Avatar
Kimko
Cruising
Default Driver door lock actuator
The anti theft part of door latch assembly is a plastic tube on the lock actuator part of the latch. It has a rod with two metal contacts that slide up and down in the tube. A two wire connection is at the top. When you look online for a replacement actuator it says the anti theft part is not included. Will post more info when I have it.
Old Apr 17, 2019 | 08:44 AM
lunaticfringe007's Avatar
lunaticfringe007
What happens if you replace it without the security feature? Or can you cannibalize that part of your old one? I may be having this problem on my passenger door.
Old Apr 17, 2019 | 09:21 AM
DVUSz06's Avatar
DVUSz06
I had the same issue when I bought my 02, passenger door would unlock but not lock, it was a small rely in the RDCM that went bad. I removed the RDCM and opened it up, and there are 3 relays in there (I think, it may be 4) I ordered relays from Digi-Key for about $3 and had a friend replace the relay and all's good. May not be your issue but worth checking out. Good luck
Old Apr 17, 2019 | 03:55 PM
Robrote's Avatar
Robrote
I replaced the relays in my door module. Not an overly hard job. Got the relays from digikey (cheap). Took an hour start to finish. Working like a charm.
Old Apr 17, 2019 | 04:26 PM
Kimko's Avatar
Kimko
Cruising
Seems I need to check the relays instead of the lock actuator.
Old Apr 17, 2019 | 07:12 PM
Jackie N's Avatar
Jackie N
Thanks for the tips guys, indeed the relays are gonna be first stop for my troubleshoot.
Old Apr 17, 2019 | 09:37 PM
laurent_zo6
Please look at the pdf in post #2. It has info on the relays.
Old Apr 18, 2019 | 05:44 PM
Rexde1's Avatar
Rexde1
I had a similar problem years ago and bought a lock mechanism off eBay for 13.00 to try. It fixed the problem and is still on the car. Most people thought it would be a relay. I got lucky I guess.
To Driver Door Lock Actuator
