washer fluid not working
Old Apr 19, 2019 | 02:59 PM
andygregg's Avatar
andygregg
2nd Gear
Default washer fluid not working
Hi,
I'm a new member and I have a question for the group. I have a 2002 corvette and the washer fluid is not working. I have two pumps,both not working, I verified the positive and negative lines are going to the correct posts, the fuse is good, and the water lines are clear, i also have 12v when the button is pressed, and the float sensor works. What else could it be??
Thank you
Andy
Old Apr 19, 2019 | 03:13 PM
rrwirsi's Avatar
rrwirsi
Do you hear the pump motor when you press the the switch? If yes, you may have a line issue. I had the same issue and found my line from the pump reservoir near the left hood hinge had been severed. Did a repair and all is good.
Old Apr 21, 2019 | 03:52 AM
Moved to C5 Tech.
To washer fluid not working
