AIR pump
Old Apr 20, 2019 | 01:30 PM
jjc508520's Avatar
jjc508520
Default AIR pump
Yanking my headlights for ACA inserts - have great access to the broken air dam retainers will definitely address that. Saw this mounted low on the drivers side - didn’t know I had a turbo! Is this the air pump that for some of you is cycling? Any PM while I can get at it? Had the buckets out in 1.5h...
Old Apr 20, 2019 | 01:31 PM
jjc508520's Avatar
jjc508520
Also all the plastic sleeves on the hinge bolts are missing - but my bump stops look OK...
Old Apr 20, 2019 | 04:31 PM
StickTail's Avatar
StickTail
Yes that is it.
You could look for any lose fasteners or corrosion/rust and broken seals. Check the hoses and connections.
To AIR pump
