So over the weekend I messed up. Forgot to unplug the 2 pin vss sensor on the dif while dropping the diff trans and tt, so it ripped the wires out of the plug. I need the pin layout with the wire color so I can re wire it up properly. If someone has that I would greatly appreciate it. Heck I’d even take a picture of the plug showing the wire colors if someone has access on their car. Thanks in advance.
also if anyone knows if the Ron Francis Wiring PG-094 is the correct pigtail that would be great too.
I did try searching but only found a bunch of threads in car audio for the speed wire hookup on the radio.
