Bleeding clutch
Old May 3, 2019 | 05:09 PM
Darrell98's Avatar
Darrell98
Default Bleeding clutch
I have a stock 1998 Corvette, I am at the clutch bleeder screw and can't seem to find the proper size wrench for the bleeder. Could someone tell me what size I need and any tricks you use to bleed it? Thanks, Darrell
Old May 4, 2019 | 09:11 PM
johnson-rod's Avatar
johnson-rod
7/16" or 11mm.
I installed a remote bleeder when I replaced the slave.
Old May 5, 2019 | 05:50 PM
justHervette's Avatar
justHervette
Cruising
I put a remote bleeder hose/valve assembly on my wife's 2003 C-5. Best $60-$70 I ever spent.
Pump clean fluid through system & placed end of hose in reservoir and pump bubbles out. One person operation.
Would have taken forever with 2 people.
To Bleeding clutch
