Climate Control Panel getting hot
Old May 3, 2019 | 07:25 PM
merv_edmunds's Avatar
merv_edmunds
Default Climate Control Panel getting hot
HI Guys, Merv from Australia here, about 6K into our USA road trip, about to start the Blue Ridge Parkway and notice the climate control panel getting hot. Everything still working, panel brightness/fan speed/all controls, but ***** and panel quite hot. Not too hot to touch but worried that something behind panel is generating non-normal heat. Still hot even if controls switched off. Any help surely appreciated, don't want to cook circuitry.
Old May 4, 2019 | 09:50 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
The climate control unit is mounted and supported but a metal frame structure that also supports the radio. Is the radio hot? Is the tunnel hot to touch? It sounds like your tunnel is generating a lot of “extra” heat. The climate control unit is a plastic box with several circuit boards, nothing that will generate the kind of heat your reporting.
Old May 4, 2019 | 11:50 AM
merv_edmunds
Thanks for your reply. No, nothing unusual about radio or tunnel, warm but usual. Driver side of panel is hotter than passenger. Drove this morning with switch off, still became hot.
Old May 4, 2019 | 02:14 PM
merv_edmunds
Hey, read on this forum about 73 being a ‘reset’ setting, anyhow things have settled down. All good so far.
To Climate Control Panel getting hot
