rear suspension Noise
Old May 5, 2019 | 04:59 PM
jimvette#1's Avatar
jimvette#1
7th Gear
Default rear suspension Noise
I have a 01 Z06 with 40K I have a "creaking" noise from the rear end area I can't figure out. As u put a load on the drive train forwards or backwards I get this "creaking" noise. Any thoughts? Thanks
Old May 5, 2019 | 09:14 PM
byte_me's Avatar
byte_me
Pull the caps off of the rims, get an impact socket and tighten the axel nuts. I had the same issue in my 01 Z with 23k miles. In fact, I completely back mine off, cleaned the threads and torqued them back down.
Ive had to do this on every C5 I’ve owned...hope this helps. Those nuts are pretty big, 33mm.
Old May 6, 2019 | 01:17 AM
Moved to C5 Tech.
To rear suspension Noise
