EBCM Replacement time
Old May 8, 2019 | 09:18 AM
ForceFedC4's Avatar
ForceFedC4
Default EBCM Replacement time
I've run down the list of things to do from easiest, to most expensive. We are now at most expensive option. I replaced the battery, cleaned all the grounds, cleaned the ignition switch connections, checked the harness, replaced the speed sensor harnesses, replaced the front wheel bearings / sensors etc. ABS & Trac lights still come on after 5 feet of moving the car after each time it's started. Codes still say right front speed sensor fault which isn't possible at this point.
I located and purchased a new EBCM from ebay which cost a pretty penny, it's going into the dealership tomorrow for them to install it I would hope this fixes the car once and for all. They quoted me around $400 for labor (this is a rear mounted early 98 car) I just want the lights to be off, and the car to pass inspection because it's been a paper weight since after they changed the clutch and these dash lights turned on and refused to turn off.
Can anybody think of anything else it could possible be? I am out of ideas.. hoping this is the solution. I asked them to give the car a state inspection once it's fixed because so far it can't pass with the safety features not working.
Old May 8, 2019 | 10:55 AM
BlackHellcat's Avatar
BlackHellcat
C5 of Year Finalist (performance mods) 2019
How is it a paperweight? Still runs & drives fine with the lights on
Old May 8, 2019 | 11:19 AM
STRMLNE's Avatar
STRMLNE
Sounds like he can’t register the car with the lights on
Old May 8, 2019 | 12:17 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Why isn't it possible at this point ??...you replaced all the parts but did you check the sensor harness "electrically" especially if it is an aftermarket part or did you just fire the "parts canon" ??...you can use a voltmeter set to AC to check the sensor side of the wheel speed sensor but checking the harness side is a little more difficult...I use a sensor simulator and a Tech 2...the sensor simulator simulates the cars tire spinning and on the Tech 2 you read vehicle speed if the harness is good...pretty sweet !!...hope you didn't spend all that money needlessly !!
EDIT: If spinning the wheel and the AV voltage is LESS THAN 100 Mv the wheel speed sensor is BAD !!...found this video !!
Old May 8, 2019 | 04:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LMFAO!!!! DO NOT TAKE IT TO THE STEALERSHIP!
CALL ME ASAP. PM SENT!!! I have the solution to your issue!! Been there done that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! FIXED!!
PM SENT!
Old May 8, 2019 | 04:40 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My 02 ZO6 had the exact same issue. Replaced the hub, jumper harness with same issue. You have to know that, the GM Female pins in all of the connectors with FLAT MALE PINS just plain *** suck bilge water!
Over time, they spread apart on their own and most all of the time fail under maintenance when you disconnect connectors.
On the front wheel speed sensors (WSS), you have the hub with a pigtail. It has MALE PINS inside the pig tail connector. They plug into Female Pins on the jumper harness. The jumper harness connector has male pins on the other end that plugs into FEMALE PINS on the connector that is attached to the top of the frame inside the wheel well. That connector/harness goes directly to the EBTCM.
Disconnect the connector on the frame and carefully inspect the female pins inside that connector. Remove some of the old male pins from the scrap parts that you have from the repair.
Conduct a "PIN PUSH/ PULL TEST" on the female pins inside the connector on the frame. You should feel a slight but noticeable resistance when you insert and extract the male pin. Bet you a cold one that one of both of the female pins are all spread apart and don't make proper connection with the male pin.
Let us know what you find.
Bill
Old May 8, 2019 | 04:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the male pin has a sloppy fit in the female pin (sound sexual doesn't?? ) that is your issue. You can replace the damaged connector OR re-pin it OR , attempt to bend the little tong inside the female pin that mates with the male pin and make the connection tighter.
I have pictures of a damaged jumper harness connector female pin compared to a BRAND NEW connector. Supply an e-mail address to send it to if you want it.
Bill
Old May 8, 2019 | 04:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
https://youtu.be/qap4m_FR2J0
Excellent vid and diagnostics,,, If you own a shop with $3000 of specialized tools!! LOL!
I would have gone straight to the connector on the EBTCM, disconnected it and used a simple multimeter set on 2 VAC and probed the pins that correlate to the front right WSS. Spin the wheel and look for that voltage . It goes from zero VAC to variable voltage (dependent on wheel speed) If you see it at that main EBTCM connector, you have good continuity all the way to the hub.
Problem occurs when cars have intermittent failures when they hit bumps in the road. Then you need to look for that bad connection, crappy female pin or damaged wire.
Bill
Old May 9, 2019 | 01:49 AM
BigGun's Avatar
BigGun
Bill
Sounds like porno to me AND you are offering pictures!
To EBCM Replacement time
