Driver's Side Lock
Old May 10, 2019 | 12:58 PM
RPGR90s's Avatar
RPGR90s
Default Driver's Side Lock
New behavior on my 2000 Vert:
Using the key fob, both doors will unlock.
Enter car and once started and moving, both doors will lock automatically above 10mph.
Stop the vehicle, remove the key, only right door unlocks. (both doors used to unlock automatically)
Press the left side unlock button and it does NOT unlock the left door. Only the right door reacts.
Press the key fob l'ock and unlock' buttons from within the car, left door is physically open, only the right side door locks and unlocks.
I checked the DIC codes on the instrument display and the A0-LDCM section displays "No Codes"
Any ideas would be appreciated.
RPGR90s
A0-LDCM - Left Door Control A0-LDCM - Left Door Control Module
Old May 10, 2019 | 01:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like on of the relays in the LDCM is bad. There are two relays. One for OPEN and one for LOCK. You can purchase the relays on the NET and replace the bad one or both.
I would also check the DIC OPTIONS page and look at the door lock unlock functions and make sure that they are still in the configuration that you desire.
Bill
Old May 10, 2019 | 01:23 PM
RPGR90s's Avatar
RPGR90s
Thanks Bill!
To Driver's Side Lock
