And and tcs codes.
Old May 11, 2019 | 06:47 PM
Joseph Morris's Avatar
Joseph Morris
Cruising
Default Abs and tcs codes.
So my car randomly throws abs and tcs alarm. It throws about twelve codes Usually and alot of codes change so its not always the same codes. Some days it won't do it. I've already cleaned the grounds. Just wondering what may cause it to do this. Any body found any issues before that have caused random multiple codes.
Old May 13, 2019 | 04:23 PM
Rover01's Avatar
Rover01
St. Jude Donor '20
Are you getting speed sensor codes as part of this? I had a loose jumper to one of the front wheels that fixed this.
Old May 13, 2019 | 04:54 PM
Joseph Morris
Cruising
Sometimes i believe got one or two speed sensors codes. What do you mean by jumper. I can check it out anyways to make sure its fine.
P.s i bought the car and i never seen these codes for weeks but then i ended up doing cam clutch bunch of other stuff i had everything out of the car as in engine and trans. I put it all back together and say after driving this started happening i looked over the car to make sure i didn't mess any wiring up and didn't notice it but I didn't see anything that stood out
Old May 13, 2019 | 05:28 PM
Rover01's Avatar
Rover01
St. Jude Donor '20
There are pigtails and connectors going to the wheels that can get loose. Check the connector/s for the wheel that shows up in the codes.
Good luck!
Old May 13, 2019 | 05:53 PM
Joseph Morris
Cruising
I went over all the connections once but ill go over it again. To make sure.
To And and tcs codes.
