Idle Glitch ??
If you have pulled codes (you can do this yourself with the car's DIC. Google it and find the YouTube video), you have no codes relating to the PCM, and the car overall appears to be running right then either (1) the car has some sort of shelf tune you weren't told about (I doubt it with just a Corsa cat back and a K&N filter, since those really aren't power mods and throwing a tune at that wastes money) or (2) at the absolute worst there's some general maintenance items lacking. On my second point for example the car may only have 31K miles and the plugs are rated to 100K but the wires are rubbing and rubber over time deteriorates exposed even sitting in a garage. If deterioration occurs in spark plugs wires it increases resistance = lesser than ideal spark.
I'd be checking the harmonic balancer and see if that's running true. That's the first thing I can think of that'll cause a cyclic vibration. Not a great piece of news if so, but I'd rather know.
Even still, sometimes it's even good to get the wrong answer, if for nothing else than to eliminate possibilities. The HB can sometimes be tough to see and be sure of. I work in a machine shop, so I look at a lot of spinning parts. It's easy to have your brain get fooled by dirt on it causing a illusion and not see the actual part running out. Seen it in videos here in the past. They're tricky. Another good thing is sometimes you can watch the belt real close (gotta check both ) but they'll have a bit of a cyclic flutter too, telling you something is wonky. Doesn't always mean it's a HB, but that is the wear part so most likely...
Having also done a lot with HP Tuners, I can say that there's a few things in a tune that can do this As a car ages the tune is no longer as ideal as it was when the motor was new. The recovery rates set for RPMs on the idla often times get to where you have a tiny bit of "hunt" for rpm. Very common when you've got a big cam and nobody set them up right. On a much smaller scale, it happens with a stock motor too.
But in his case, low miles car, one owner, with almost certainly the OEM balancer, and he just did some high rpm runs.... That's where I would start.
Even still, sometimes it's even good to get the wrong answer, if for nothing else than to eliminate possibilities.The HB can sometimes be tough to see and be sure of. I work in a machine shop, so I look at a lot of spinning parts. It's easy to have your brain get fooled by dirt on it causing a illusion and not see the actual part running out. Seen it in videos here in the past. They're tricky. Another good thing is sometimes you can watch the belt real close (gotta check both ) but they'll have a bit of a cyclic flutter too, telling you something is wonky. Doesn't always mean it's a HB, but that is the wear part so most likely...
