Front Turn Signals/DRL are not illuminating
Installed new front corners and LED switchbacks. All works great, then nothing. Fuse #2 is good. Rear blinkers work. Is there a common ground for them or is it separate for each side? I believe the multi-function switch is ok, with the rear blinkers working. Hazards work, minus the front bulbs. DLR fuses in the passenger floorboard are ok. Any ideas appreciated. Both side stopped working at the same time after install of new RadioFlyer headlights. Any ideas appreciated.
My parking lights nor DRL/turn signals turn on when the parking light and headlights are on.
