brake cable connection to ignition switch
Old May 24, 2019 | 01:55 PM
tabbruzz's Avatar
tabbruzz
Default brake cable connection to ignition switch
What is the secret here on disconnecting it please? I see the black clip and I push it up and it moves a bit but is seems like something else has hold of it inside the switch. I do not want to break it....Any help would be great.
Old May 24, 2019 | 04:44 PM
tabbruzz's Avatar
tabbruzz
Found the secret....no replies necessary
Old May 25, 2019 | 09:38 AM
TomWoodgeard's Avatar
TomWoodgeard
St. Jude Donor '12
OK...................................... .................. For the rest of us, what was the secret?????????????
Old May 25, 2019 | 12:32 PM
tabbruzz's Avatar
tabbruzz
The ignition. Switch must be in the ON pisition....comes right out then after you push the little clip up under the cable connection
Old May 25, 2019 | 12:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! Turning the switch to the ON/RUN position is the secret to:
1- Removing the brake cable. Just press the release tab on the cable connector.
2- Removing the ignition switch key cylinder Once the key is in ON/RUN, just press the small tab on the side of the cylinder barrel.
Old May 25, 2019 | 06:32 PM
TomWoodgeard
St. Jude Donor '12
Thank you both. THIS is how we learn......
To brake cable connection to ignition switch
