Heat coming from center console..
Old Nov 5, 2002 | 07:49 PM
Pewter Power's Avatar
Pewter Power
Default Heat coming from center console..
Has anyone experienced this issue? I have a 99 and noticed after driving the car for a good 45 minutes at normal driving speeds (hwy and street) that there was a good deal of heat coming from the center console. You could feel it if you put your hand between the passenger and driver seats and the center console. It felt like the heat was on...
Any thoughts?
-Thanks
Old Nov 5, 2002 | 08:02 PM
WWK888's Avatar
WWK888
Default Re: Heat coming from center console.. (Pewter Power)
Normal...
Old Nov 5, 2002 | 08:06 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Heat coming from center console.. (WWK888)
Normal...
:yesnod:
vetterdstr :cheers:
Old Nov 5, 2002 | 08:37 PM
THENAKEDi's Avatar
THENAKEDi
I remember, during the initial road test of the C5 by one of the mags, the writer commented about how he had left a chocolate bar in the console for later consumption. To his surprise, he had a chocalate treat waiting for him in the console...melted everywhere!
Old Nov 5, 2002 | 08:48 PM
Pewter Power
Thanks for your response...
Old Nov 5, 2002 | 09:22 PM
viperZ06's Avatar
viperZ06
normal :yesnod:
Old Nov 6, 2002 | 01:50 AM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: Heat coming from center console.. (kgrif)
I noticed this when I first got my vette. But it seems to have almost gone completely away after I added on some coated longtube headers. Maybe it is my imagination, but I feel no major heat coming from the tunnel anymore. Anyone else notice this after longtubes?
[Modified by QuickSilver2002, 5:51 AM 11/6/2002]
Old Nov 6, 2002 | 02:06 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Heat coming from center console.. (QuickSilver2002)
I have long tubes and still get alot of heat.. but mine are not wrapped..
Old Nov 6, 2002 | 10:29 AM
jerryv's Avatar
jerryv
If they'd mount the cup holder in the right place it would make a great hot chocolate warmer :) Don't put anything heat-sensitive in the console.
Old Nov 6, 2002 | 10:35 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Re: Heat coming from center console.. (Jerry Velders)
there's a heat blanket for that area , but they charge like $400 for the thing...
Old Nov 6, 2002 | 10:37 AM
vetterdstr's Avatar
vetterdstr
Look at it this way, now you dont have to microwave those frozen burritos from 7/11 anymore. Just pop them into the console and by the time you arrive at your destination... you have a hot lunch waiting for you! Now how many car makers can say that?? :smash:
vetterdstr :jester
Old Nov 6, 2002 | 01:20 PM
johnnyC5's Avatar
johnnyC5
Default Re: Heat coming from center console.. (Grumpy)
I have LongTubes too, but still gets really hot.
Wonder if those KoolMat blankets do the trick. They are WAAAAy overpriced though
does the tranny emit any kinda heat? wolud a tranny cooler help in any way?
Old Nov 6, 2002 | 01:31 PM
Stu in CA's Avatar
Stu in CA
It's nice in the winter when the top is down. :D
I had to insulate my rear center compartment too, for our lunchboxes, as that area gets the tranny and over-axle pipe heat.
I have LT's and still have the heat from console. When I had the driveline out I saw that the whole car is just pretty tight in that area, exhaust is tucked right up in the cavity. Next time exhaust is out I'm going to wrap the pipes with that tape stuff and see if it helps, I'll let you know.
Old Nov 6, 2002 | 01:44 PM
MO-JO's Avatar
MO-JO
Cruising
Default Re: Heat coming from center console.. (johnnyC5)
Heat is normal and by the way the transmission is not under the tunnel, it is located by the front of rear end. Ever check your tranny fluid? Think this is hot ride in C3, C2 without insulation.......... :chevy
Old Nov 6, 2002 | 01:54 PM
KingTut's Avatar
KingTut
Default Re: Heat coming from center console.. (MO-JO)
Speaking of insulation - search for Evil-Twin and his interior insulation. I did this mod and my center console is now the same temp as the floor boards or any other part of the interior. It is also quieter besides. Took about $60 worth of material but did take about 15 hours for the whole thing.
Old Nov 6, 2002 | 06:12 PM
rrobert22's Avatar
rrobert22
normal :yesnod:
Normal, and you can cook while you drive :yesnod: Just like Kramer did on Seinfeld :lol:
Old Nov 6, 2002 | 06:17 PM
chuckster's Avatar
chuckster
The heat is coming from the Catalytic Converters. They get mucho hot...
Remove them and it is a night and day difference... ;)
Old Nov 6, 2002 | 09:07 PM
vetterdstr's Avatar
vetterdstr
I have that heat blanket and it works well. :yesnod:
vetterdstr :cheers:
Old Nov 7, 2002 | 08:36 AM
THRAP 42's Avatar
THRAP 42
Pewter Power,
I removed the seats and center console and wrapped the area with a product called "Reflectiv". Works pretty well overall but there is still a very warm area next to the shifter. Pleased with the time and effort it took to do the install. Reflectiv is available at Lowe's.
later,
To Heat coming from center console..
