Low oil level message
Old May 24, 2019 | 12:11 AM
mmo24's Avatar
mmo24
Default Low oil level message
So I did some searching through old threads related to the low oil message and couldn't find an answer for my question. I'm curious how much oil is in the motor when The message displays? Thanks.
Old May 24, 2019 | 01:15 AM
helives4u2's Avatar
helives4u2
Not enough, lol
Old May 24, 2019 | 01:57 AM
mmo24's Avatar
mmo24
Originally Posted by helives4u2
Not enough, lol
No way!!
Old May 24, 2019 | 02:18 AM
My Vette Life's Avatar
My Vette Life
Not enough, lol
No way!!
no it's true. The very first month of owning the c5 I was down 4qts before the message came up. Regardless you should inspect your car least twice a month. Why would you not???
Old May 24, 2019 | 03:55 AM
mmo24's Avatar
mmo24
The reason I'm asking it because, My Warning came on so I added a quart and then checked my dipstick and it read full. Seemed weird that the warning would come on for only a quart low.
I check my oil and all other fluids every other time I fill up on gas.
Old May 24, 2019 | 10:00 AM
DetroitPlac's Avatar
DetroitPlac
Mine also comes on at a quart low.
I put 5.5 quarts in it instead of 6.5 quarts at my last oil change because of a brain fart. As soon as I fired it up, oil pressure built fine but the low oil level warning came on. Checked the manual, felt like an idiot, added the extra quart and the warning went away.
Probably shouldn't have admitted that, but I learned what triggers the low oil level warning in my car!
Old May 24, 2019 | 02:20 PM
My Vette Life
Glad to hear that!
I daily my C5 by choice and I guess you can consider it on double duty for those back road top speed runs. That's good it show's low just with 1qt, mine still will not show until I'm 4qts low. Could it possibly be a bad sensor somewhere? Sure, but for 1qt low I would take that any day rather than 4qts.
Old Aug 10, 2019 | 11:55 PM
KingTut's Avatar
KingTut
Default First time in 18 years
For the first time in the 18 years I have had the car, the low oil level message appeared. I added one quart and it was back fine on the dip stick. Like the others, I came on here to see if it could be that sensitive, and I guess it can.
Old Aug 11, 2019 | 01:55 AM
jdmvette's Avatar
jdmvette
Night Owl for life
try replacing the sensor next time you change the oil.
Old Aug 13, 2019 | 09:59 PM
REDXTC's Avatar
REDXTC
Usually 1 quart low hits the low mark on the dipstick. That is when you want the warning to come. You don't want to be driving with low oil levels.
Old Aug 13, 2019 | 10:02 PM
glbeauchamp's Avatar
glbeauchamp
One quart low when mine came on. Scared the hell out of me until I checked the dipstick and saw it was only one quart down. Ordered a new sender just in case but didn't have to install it. Only cost about $20.
Old Aug 14, 2019 | 05:17 PM
grinder11's Avatar
grinder11
Default Low oil......
I found out the following info by accident years ago. Had my 2000 C5 at the dragstrip on a day when, unbeknownst to me, the low oil level warning in the DIC was ready to come on. I made several runs, and noticed the mph was higher than normal, by approx 2mph. Thought it was due to better weather conditions. Then I made 1 more run, thinking man it's running good today!!! THEN-LOW OIL Warning flashes!! I was freaked out!!! Oh no, I damaged something. But like you, I soon found out it is triggered when oil is down 1-1.5 quarts. The extra speed was explained by Kurt Urban as "decreased windage losses due to more air space in the sump, because of a lesser amount of oil". Not that I would recommend running an engine with the oil a quart low!!!!
To Low oil level message
