turn signal question?
Old May 25, 2019 | 10:09 AM
shot410ga's Avatar
shot410ga
Default turn signal question?
My right-hand turn signal beeps and flashes normally, however my left-hand signal beeps very rapidly,. But, all the turn signals (bulbs) work. Any guess as to what caused this? It just started the other day. Never happened before.
Old May 25, 2019 | 12:21 PM
BAT's Avatar
BAT
2026 Corvette of the Year Finalist - Modified
2025 C7 of the Year Winner - Modified
2024 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year FinalistAX - Modified
Any chance there's a different type of bulb (LED) in one of the left sockets? If so, you'd need a hyper flash harness, or switch it out to a regular bulb.
Old May 25, 2019 | 01:22 PM
awches's Avatar
awches
Not sure if you problem was always or just lately without changing anything. What I can say as I just had a problem when changing a turnsig bulb on one of my bike and it hyper flashed. Come to find out that even though the same voltage, was different wattage which cause the hyper flash. Got the right bulb and all is good.
Old May 25, 2019 | 01:53 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
bad 4 way flasher switch, next time try pushing it rapidly and see if turn signal works then ???
Old May 25, 2019 | 03:35 PM
shot410ga's Avatar
shot410ga
Nothing has been changed. Just started doing it.
Old May 25, 2019 | 03:36 PM
shot410ga's Avatar
shot410ga
Thanks, I will try that. No bulb has been changed and they all work.
Old May 26, 2019 | 02:38 PM
Moved to C5 Tech.
Old Sep 14, 2019 | 11:57 AM
0VERKILL's Avatar
0VERKILL
@shot410ga Did you ever figure this out? My left hand signal just started doing this last night. Mine does have LED tail lights, but it never did the hyper flash until yesterday. No idea where to begin looking as the car is pretty new to me. My daughter confirmed the bulbs are working, although I probably need to check that myself.
To turn signal question?
