Air leak 2
Before I get hit with double posts and such, it was suggested that I transfer to here for better results...
I have done some research here, and have not found what I am looking for.
My issues are as follows;
1) Air rushing in at highway speeds in the center, between the Targa, and the top of the windshield brace. When you get out, you can actually push it down a little, so that it is lower than the seal that is mounted to the windshield brace.
2) The driver and passenger windows will not go behind the tab that is supposed to hold them in place while driving at moderate speeds. The tab is the one that is mounted to the Targa top.
I understand there is a need to adjust the windows possibly up and in more. But, what is too much. I adjusted the height so that when the door shuts, it just clears the tab. The problem is if you lower the window while driving, and raise it up, it will not go back under the tab.
So, guru's, where do I start, and how do I fix these issues?
Regards...
