IDLE RELEARN
Nov 6, 2002 | 10:25 AM
IDLE RELEARN
I put on a vortex power duct and MAF housing with airfoil...also corsa Indys on my 1999 coupe.......idle is a lil rough...my buddy was explaining an idle relearn the other day but I forgot what was involved...any help on the procedure would be great........also will I notice a big diff in idle afterwards?
Thanks Guys
Marc
Nov 6, 2002 | 10:40 AM
Re: IDLE RELEARN (skidmarc)
ttt :D
I need to know also....
:cheers:
St. Jude Donor '11,'13
call mallett cars they will tell you exactlly what to do 440-243-8550 :cheers:
Nov 6, 2002 | 11:08 AM
Automatic Transmission:
1 Turn off the ignition
2 Restore the PCM battery feed
3 Turn Off the AC controls
4 Set the parking brake and block the drive wheels
5 Start the engine
6 Allow the engine coolant temperature to reach 176 degrees F
7 Shift the transmission selector into the drive range
8 Allow the engine to idle for 5 minutes
9 Turn on the AC controls (Omit for 2000-01 model)
10 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
11 Shift the transmission selector into Park
12 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
13 Turn off the AC controls (Omit for 2000-01 model)
14 Allow the engine to idle for 5 minutes
15 Turn off the engine for 15 seconds
Manual Transmission:
1 Turn Off the ignition
5 Transmission in neutral
6 Start the engine
7 Allow the engine coolant temperature to reach 176 degrees F
8 Turn on the AC controls (Omit for 2000-01 model)
9 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
10 Turn off the AC controls (Omit for 2000-01 model)
11 Allow the engine to idle for 5 minutes
12 Turn off the engine for 15 seconds
:cheers:
Nov 6, 2002 | 12:39 PM
Re: IDLE RELEARN (Patches)
patches, please tell me more about restore the pcm battery feed and block the drive wheels :confused:
Nov 6, 2002 | 12:54 PM
Re: IDLE RELEARN (stunna)
"Restore the PCM battery feed"
Reconnect the battery if it's disconnected.
"Block the drive wheels."
Get a set of wheel chocks designed to be placed in front of the tire to keep the car from moving when it's in gear. This is especially important on an A4 when the car is put in Drive. Blocking the drive wheels keeps the car from moving while doing the relearn.
:cheers:
Nov 6, 2002 | 04:12 PM
i have never hered this way of doing it i know about the ac and all that but put the parking brake on and shift from drive to park also why is it important the wheels dont move :confused:
Nov 6, 2002 | 04:19 PM
Patches procedure works. I used it and it works.
Nov 8, 2002 | 10:43 AM
guys do I need to do anything with the heater? or just ac due to compressor?
Nov 8, 2002 | 10:52 AM
Just the A/C. :cheers:
2001 ,
2002 ,
c4 ,
c5 ,
cars ,
corcette ,
corvette ,
idle ,
learn ,
learnidle ,
ls1 ,
mallett ,
relear ,
relearn ,
reset
