Front-mount oil cooler hose length?
I'm in the last stages of figuring out my components for a front-mount oil cooler setup. I've measured some stuff and seen other builds, but would love a sanity check from anyone who's done this or seen it done, for the oil lines. I'm having ImprovedRacing do the line assembly for me, because they're great, and I'd love to make sure my lines fit.
(They don't have the figures on hand for the right length.)
I'm planning on using their MHX-245, roughly behind the license plate area. Gonna cut that out for airflow etc. Seems to be enough space.
I made some measurements using heater hose and got somewhere in the 6 foot range, maybe 6.5. Can anyone confirm these figures or share their own? If you've put a much smaller cooler there (the MHX-245 is 21.20" long), please share that as well so I can compensate.
(I have a dewitts rad, which is thicker than the standard + intercooler + I'm keeping the AC condenser + I'm about to put a Callaway Honker in the standard area where one would usually mount an oil cooler, so I'm going for a front-mount setup instead.)
I think you should run the simulated lines to and from where the actual lines will go, make sure there is clearance and plan for heat protection where either of them go close to hot things like exhaust manifolds. Also plan for any supports, hangars or abrasion protection of other fluid carrying lines..
If you are planning to use stainless steel braided lines, keep in mind that the stainless steel braiding can be quite abrasive on things it rubs on or vibrates against, like power steering hoses or coolant hoses.
I'm gonna use IR's BMRS+Firehose prefab setup. No chafe!
Edit: I went with 6.5 foot lengths. I will update how that goes.
https://www.corvetteforum.com/forums...s-today-2.html
The answer is 6.5 feet (x2) for the hoses to mount in the center behind the front bumper lic plate.
