2004 vette oem brake pad material?
Old Jun 12, 2019 | 09:36 PM
nmbsun's Avatar
nmbsun
Default 2004 vette oem brake pad material?
Some parts houses say Semi-Metallic, others say Ceramic. I liked the way my brakes worked when the car was new and I want to put back the exact same pads. Thanks in advance.
Old Jun 13, 2019 | 12:23 AM
STRMLNE's Avatar
STRMLNE
I’m curious about this too. I’ve always used oem pads but they were just recently discontinued. Might want to buy up some rotors if you like the oem. I’m guessing they will be discontinued as well here shortly.
Old Jun 13, 2019 | 08:00 AM
nmbsun's Avatar
nmbsun
Amazon has AC Delco pads but they are Semi-Metallic but it says on the page that OEM is Ceramic. Same for Summit racing AC Delco pads. But from what I know about brake pads Semi-Metallic are for hard driving and Ceramic are more sensitive to cold weather and have other negative things that one does not want in a performance car.
If I can't get a real answer to my question I am either going with AC Delco Semi-Metallic or Wagner ThermoQuite MX731 for the front.
Old Jun 13, 2019 | 10:37 AM
GCG's Avatar
GCG
Originally Posted by nmbsun
Amazon has AC Delco pads but they are Semi-Metallic but it says on the page that OEM is Ceramic. Same for Summit racing AC Delco pads...
OEM pads are not ceramic. This has been discussed before, the original AC Delco pads are Semi Metallic Carbon Ferrous, according to Evil-Twin. Click here for some interesting insider's details.
Old Jun 13, 2019 | 11:36 AM
STRMLNE's Avatar
STRMLNE
Anyone know who sells oem pads? I can’t find them anywhere
Old Jun 13, 2019 | 01:10 PM
nmbsun's Avatar
nmbsun
This is as close as I can find.
Amazon Amazon
Old Jun 13, 2019 | 01:21 PM
c4cruiser's Avatar
c4cruiser
While those pads at the Amazon link will work on C5's, they are described as "semi-metallic", there is a note that says OEM C5 pads are ceramic. Looking a bit further, AC Delco "Advantage" pads are ceramic while the AC Delco "Professional" pads are semi-metallic.
Old Jun 13, 2019 | 03:24 PM
GCG's Avatar
GCG
Front:
Click here Click here
Rear:
Old Jun 13, 2019 | 06:51 PM
jrprich's Avatar
jrprich
Originally Posted by GCG
Front: Click here
Rear: Click here
I put these pads on my 99 and again on my 03. They work well and are quiet.
Jim
Old Jun 14, 2019 | 02:45 PM
nmbsun's Avatar
nmbsun
Jim
I see where these pads come with shims. Do you need to install the shims?
Old Jun 14, 2019 | 08:59 PM
jrprich's Avatar
jrprich
If you mean the plates that come attached to the back of the pads, yes I used them but I do not know if you are required to.
To 2004 vette oem brake pad material?
