Using stock pushrods w/cam as test
Old Jun 15, 2019 | 10:54 AM
bwill03z's Avatar
bwill03z
Default Using stock pushrods w/cam as test
Would it be ok to throw the factory pushrods back in and keep it at low rpm’s just as a test with an aftermarket cam to see if valvetrain noise is any different? I currently have 7.400 pushrods and I was going to experiment with less preload. I’d hate to order a set of pushrods for $100 and then turn around and have to try and sell them
Old Jun 15, 2019 | 11:41 AM
vettin_it's Avatar
vettin_it
Yes it will be fine to test with.
Old Jun 15, 2019 | 12:08 PM
bwill03z's Avatar
bwill03z
So just unbolt the rockers, toss the new pushrods in and torque the rockers back down to 22ft lbs making sure the pushrod is seated good in the rocker?
To Using stock pushrods w/cam as test
