C5 vent door actuator replacement question
Old Jun 15, 2019 | 12:36 PM
crusinC5's Avatar
crusinC5
4th Gear
Default C5 vent door actuator replacement question
I have a 2001 c5 corvette. On a hot day, it was blowing hot air on drivers side and cool on passenger side. I pulled the HVAC fuse, and it corrected the problem, until the next time I went to use the car. I tried that multiple additional times, but it never worked again. I purchased a dorman air door actuator, removed the dash and installed the unit. After I put it all back together, it did not solve the problem. I called dorman and they said try a hard reset (pull power to battery, turn on key for one minute to drain power). That also didn't work. I just pulled the unit, looking to go get a replacement (maybe it was a defect). I noticed that both the original unit and the dorman unit were stopped in the same direction (far right), but when I installed it, the position was in the center. Any suggestions.
Old Jun 15, 2019 | 09:27 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
there are different dorman parts...you probably got the wrong one, they are very specific....they look the same but they are not...sucks I know
Old Jun 15, 2019 | 09:44 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
Do you have the manual AC or Dual Zone climate control? Also, how much did you pay for the actuator. The $50 ones are for the manual system and the $90 ones are for the climate control.
Old Jun 16, 2019 | 08:46 AM
crusinC5's Avatar
crusinC5
4th Gear
I have the Dual Zone Control, and the one I purchased was $141 from Advance Auto Parts (part no 15490052, 604-106).
Old Jun 16, 2019 | 08:48 AM
crusinC5's Avatar
crusinC5
4th Gear
The one I pulled out has an R on it, but that was not an option when I bought the new part from Advance Auto Parts.
Old Jun 16, 2019 | 08:56 AM
K-Spaz's Avatar
K-Spaz
Well that definitely sounds like the right one. A bit much on the price. Unless you have something blocking the door, like a walnut or something , I have no idea why it wouldn't be cycling correctly. It's been some years now since I messed with them but I know the d z ones have a potentiometer in for position feedback. I'm wondering if there isn't something happening with that signal.
Don't throw away the one you took out, it likely is just fine.
Old Jun 16, 2019 | 09:57 AM
crusinC5's Avatar
crusinC5
4th Gear
Luckily I kept the original one. I still have the dash off so I will check to make sure nothing is blocking the full motion. I did check the movement of the vent and it moved easily by hand, but I didn't check if that was full motion.
To C5 vent door actuator replacement question
