p0410 check engine light
Old Jun 15, 2019 | 08:10 PM
Welch27's Avatar
Welch27
Cruising
Default p0410 check engine light
My check engine light came on with the p0410 code (1998 auto Vert) I can hear my secondary air pump turn on so I am guessing my Check Valves need to be replaced. Since the passanger side Valve is hard to reach I thought about running a new hose to relocate the Valve. OR I could do the Ls6 intake manifold swap and fix the valve.
Would greatly appreciate any input from you guys. Do I need a Dyno tune after the ls6 intake swap? Does it mess passing SMOG here in Cali?
Old Jun 16, 2019 | 11:26 PM
02torchred's Avatar
02torchred
Most know there are many vacuum lines from the gas tank to the engine, and the PCV vacuum lines.
But wait! There's more! We also have the air system you mentioned. This has a vacuum line running from the air pump (bottom driver side in bumper) running all the way across the front of the car, back across the passenger side frame into a spot near the PCM (passenger fender well) onto a series of T and right angle connections that go to a vacuum canister.
Then there is the AC system. That vacuum line runs from the passenger side firewall grommet (coming in from the many lines inside the dashboard from the vacuum-controlled vents), to underneath the battery tray, and meets the Air Pump System's line into the PCM spot. They meet and join at that canister. There is also another line that goes from this canister to the back of the intake manifold: the main source of vacuum and why leak codes are formed.
All those lines are a hard very brittle plastic that break over time. Any of those connections, (probably totaling 15 feet of it, including ANY of the connections in the dash) can break in one or more spots and cause vacuum leak codes, like the P0410. To add to this, most of the lines are wrapped up in electrical wires, underneath a conduit, and electrical tape.
Old Aug 27, 2019 | 03:13 AM
Relly98C5's Avatar
Relly98C5
Cruising
I’m having the same problem does anyone know if this code can be tuned out and still pass smog in California?
To p0410 check engine light
