Anyone Experience Column Lock with 2000 - 2004 Automatic Trans
Old Jun 21, 2019 | 01:49 PM
milano maroon's Avatar
milano maroon
Default Anyone Experience Column Lock with 2000 - 2004 Automatic Trans
Just started learning about some of the common C5 failure points. I have a 2002 with an automatic transmission (U.S. car). The Compliance Parts website says my car is not in the series where the column lock issues occur, Do I need to worry about column lock issues, or "Pull Key Wait 10 Seconds", or 2 mph fuel cutoff? I guess my real question would be - has anyone with a 2001 2000 - 2004 with A4 transmission experienced this and do I need to buy and install the LMC5 module?
I have had absolutely no issues yet but I've only owned the car a year or so. My car has 51,000 miles on it right now.
Thank you for advice you guys can offer.
Jeff
Last edited by milano maroon; Jun 29, 2019 at 08:20 PM. Reason: had wrong information
Old Jun 21, 2019 | 02:01 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
think with 99 % certainly it's just the manual cars !!!!
Old Jun 21, 2019 | 02:13 PM
Kevin-2001C5's Avatar
Kevin-2001C5
I believe for the later C5s, GM removed the lock.
Old Jun 21, 2019 | 02:46 PM
Smoken1's Avatar
Smoken1
I have never had a problem with my 02 vert with the A4 trans and I have owned it for 12yrs
Old Jun 21, 2019 | 09:54 PM
ncali's Avatar
ncali
I have a 2000 with an auto. I installed the lmc5 because I know that I wouldnt have a problem with the column lock until
I were away from home , out with someone, getting off of work, 100 degree day with no tools and I would be Fxxked
so for 50.00 I wont have that problem
Old Jun 22, 2019 | 02:16 PM
MatsA's Avatar
MatsA
2024 C6 of the Year Finalist - Modified
If you have a 2002 with A4 no need to worry only the manuals retains the lock feature these later years from 2001- later i think it was the wheel lock was removed.
Old Jun 25, 2019 | 12:37 PM
milano maroon
Thank you all for the replies.
Jeff
Old Jun 25, 2019 | 01:17 PM
Robrote's Avatar
Robrote
I had the 2mph shut off and 'pull key and wait', message on my 2000 A4. I did the compliance bypass. No issues since. My car had the column lock disabled from the dealer (steering wheel turns without the key on) .
Old Jun 29, 2019 | 08:18 PM
milano maroon
So I goofed when I asked the original question. According to Compliance 1997 - 2000 years with the A4 are susceptible to column lock / 2 mph fuel cutoff issues. So like some of you already said the 2001 to 2004 A4's (mine being a 2002) are OK. Just wanted to correct my post so no one else has bad info.
To Anyone Experience Column Lock with 2000 - 2004 Automatic Trans
