C5 2000 head lights
Old Jun 24, 2019 | 05:49 PM
FASTFURIOUS's Avatar
FASTFURIOUS
Cruising
Default C5 2000 head lights
Headlights come on but the pop up doesnt work on either side,,,,NO motor noise at all. Right side started this a few months ago but would work with on / off application. Now left side and right side will not pop up,,,,fuses look good.. Waz up???
Old Jun 24, 2019 | 07:27 PM
gimp's Avatar
gimp
Can you manually raise and lower the lights?
Old Jun 25, 2019 | 10:45 AM
jjc508520's Avatar
jjc508520
Some info here from my ordeal. My issue was resistance (lack of it) with the HID ballasts I swapped in - still - some useful debug info here....
https://www.corvetteforum.com/forums...ja-needed.html
Old Jun 27, 2019 | 08:56 PM
FASTFURIOUS
Cruising
Thanks , no neither of them will move, cant move manually...relay sounds like its kicking in but will not activate .
Old Jun 27, 2019 | 09:19 PM
gimp's Avatar
gimp
If you can't move the lights manually, you likely have stripped gears inside. I recommend taking each motor out, taking it apart, and buying the ~$55 motor repair kit with brass gears, steel T-brace, and shims.
Old Jun 27, 2019 | 10:48 PM
GCG's Avatar
GCG
It seems you probably have the plastic gear broken in both motors.
Get a kit like this one (pay attention because there are 2 different kits: one for "97 to early 2000" and another for "late 2000 to 2004") and follow these step-by-step directions. You'll save money and they will last forever.
It would be wise to replace as well the rubber bump stops in both sides (#4 in diagram below). You can get them here.
There is a TSB, that calls for shimming the driver's side motor. The parts needed for this are included in the above mentioned kit (#2 in diagram below).
To C5 2000 head lights
