2004 z06 window problems
Old Jun 25, 2019 | 08:08 AM
Brawleysz06's Avatar
Brawleysz06
4th Gear
Default 2004 z06 window problems
I have a 04 z06 and out of the blue yesterday my driver side window started acting up, it will roll down while door is closed when I first start car up but won’t go back up, if I open the door it will roll up, anyone had this issue and what was the fix. Thanks in advance
Old Jun 25, 2019 | 09:10 AM
chris308's Avatar
chris308
Check the wiring and harness connections at the door "accordion" boot.
Can't remember if the door switches are interchangeable due to plug size but maybe swapping the sides to see if you might have a bad switch in another idea...
Old Jun 25, 2019 | 09:38 AM
Brawleysz06
4th Gear
Ya I’m going to check the boot tonight, I assuming that’s where the plugs are?
Old Jun 25, 2019 | 09:44 AM
chris308's Avatar
chris308
Should just be a pass thru for the wiring but the wires sometimes get pinched...
Old Jun 25, 2019 | 09:48 AM
Brawleysz06
4th Gear
Ok I’ll take a look tonight, I would think it’s something stupid since it works when doors open
Old Jun 25, 2019 | 11:59 AM
Moved to C5 Tech.
To 2004 z06 window problems
