EBCM piece broke off
Old Jun 27, 2019 | 01:01 AM
shems's Avatar
shems
Default EBCM piece broke off
The picture of my issue should be attached.
The story is I am doing that thing where you have to solder those 5 points on the ebcm because the TC and ABS stopped working and all was dandy but when I was trying to crack it open with a mallet, one of the cylinder things came off. Does anybody know what this part is? And if this is fixable? Thank you very much!
File Type: pdf
Old Jun 27, 2019 | 01:05 AM
shems's Avatar
shems
Default JPEG photo
a
Just incase it didn't post in the first post. Here is the picture of the module with the broken piece.
Old Jun 27, 2019 | 06:37 AM
robmiz's Avatar
robmiz
Looks like to me valve solenoid magnetic coil, which when energized operates plunger or valve rod.
Old Jun 27, 2019 | 11:19 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Can you get to the back side of that board? Looks like they had leads on those coils and soldered from the back side. If so, you could add leads again, JBweld the thing to the board, and solder from the back again. But you'd need to desolder that board real well to make sure the holes were opened good. Fact is, I might not resolder back there, I might be inclined to solder wires on the coil ,then re-route them back around to the back side of that board and solder then there (vs sending heat through to the part you just got done soldering the leads back on.)
To EBCM piece broke off
