Control non dr side
Control non dr side
Can anyone tell me if the control *** on driver side turns without stoping the passenger side will stop in cool or hot range my passenger side works fine When on ac the driverside doesn’t get as cold as passenger-side help c 5.
Received 19,738 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
If it's not getting cold, you most likely have an actuator problem. There is a procedure to reset them. If that does not work, it will need to be replaced. Sorry, I do not know the reset procedure but if you do a google search, it'll pop up.
Rob
Rob
