hanging idle
Old Jul 12, 2019 | 10:11 AM
tabbruzz's Avatar
tabbruzz
Default hanging idle
Guys,
I have a hanging idle in park when I rev the engine it goes up to whatever then stops for a second or two between 1200-1500 prior to it dropping to my idle at 775.......I did my research and did see what should be done and I just loaded a few updates(have not tested yet as I am working) but what is the main source or change that typically helps this most? Timing around the lower rpms, throttle follower, base idle airflow??? I had an updated tune due to the addition of a SC on a dyno, but I physically removed my MAF and that seemed to change things slightly......So I will certainly try what I found out so far, but any feedback is welcomed...Thanks
Old Jul 12, 2019 | 11:41 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
THE VERY FIRST THINGS TO DO ARE:
1. Check for any un-metered air entering the engine
2. Vacuum leaks.
Check your long and short fuel trims. Report what they are.
Bill
Old Jul 12, 2019 | 12:28 PM
tabbruzz's Avatar
tabbruzz
2. Vacuum leaks.
Bill
Ahh yes.....more info would be helpful
A&A V3SI supercharger
Running speed density
no MAF physically installed
car is setup rich up to but runs 14.7 at part throttle and idle
LTFT off
STFT hover +- 10 on average.... but generally closer to zero on average
auto tranny with 3200 stall
headers, ls6 intake ported TB...
Pump 93, no meth
Old Jul 12, 2019 | 12:41 PM
feeder82's Avatar
feeder82
Here's a fix from the tuner school
Old Jul 12, 2019 | 01:14 PM
tabbruzz's Avatar
tabbruzz
Originally Posted by feeder82
https://youtu.be/MxnnFDpy2-4
Thanks for the link... This is for dirving around though...I have this issue in park....I will see if I can do the same with the throttle follower..To be honest I need to verify if it does this in drive. I did not notice it, but maybe its there as well...Thanks
To hanging idle
