High Trans Temp, 194F
Old Jul 13, 2019 | 04:13 PM
AndersG's Avatar
AndersG
1st Gear
Default High Trans Temp, 194F
Hi,
I have been reading alot of the threads in here ,and it seems that there alot of knowledge collected under one roof. Of course I do hope that you guys can help me with my problem, that starts to get on my nervs...
In the DIC it says "High trans temp / 194F", even if the car is cold just before start. So obviously I don't have any problems with heating. First I started with the obvious, change the temp sensor (located inside the pressure plate, inside the transmission), but no difference and same message.
Then I continued to measure the 2 cables that comes from the PCM, but all ok. So, any of you guys that can help me that have had similar experience?
// Anders
