HELP! Overheating coolant
Old Jul 15, 2019 | 02:28 PM
Dranir's Avatar
Dranir
Originally Posted by Bill Curlee
Is there air flowing THROUGH the AC Condenser and Radiator?????
There is a very common problem with our C5s. There is a 1" space between the AC Condenser and Radiator. It commonly gets clogged with grass/trash/sand/dirt. You need to pull the air bridge and the plastic cover over the radiator and inspect that space.
BACK Flush the cooling fins with a garden hose on direct stream and see what all comes out. After that procedure see if it returns back to normal.
Also look at the cool air intake in front of the car and make sure its clean and not blocked with trash/leaves/dirt.
Everything is actually quite clean.
Old Jul 15, 2019 | 02:30 PM
Dranir's Avatar
Dranir
Originally Posted by GCG
It seems the Low Speed mode is not kicking in. That would explain what's happening!
Both fans are supposed to start in low speed at 226°F. If temperature continues to raise and reaches 235°F then they change to high speed. Once temperature drops back to 226°F they change to low speed again, and if temperature reaches 219°F they are turned off.
But regardless of the low-speed kicking in, shouldn't driving 40mph create enough air flow for the radiator?
And yes, the scoop is still installed under the bumper.
Old Jul 15, 2019 | 02:31 PM
Dranir's Avatar
Dranir
Originally Posted by Josephu
Take out the thermostat and put the housing back on..;;;;Fill it back up. Fire up the motor and see what happens. If it still overheats, then you have a restriction somewhere. Did you verify that the radiator would flow collant?.....Hose in one end and watch flow at other end?? Run water through the block with a garden hose. Hose in the top hose and watch water come out the bottom. It would be nice if you could put an A/C thermometer in the radiator somewhere and run the motor. Compare block heat to radiator heat. Im leaning towards that radiator,,,, As they get old, they loose their ability to transfer heat from the tubes to the fins. Usually they dont go bad instantly.. It takes a period of time. Try these things and see what happens. My bet is on that 16 year old radiator.
Thanks. I hope it's just the radiator.
I actually can't do that thermostat trick since I have one with the integrated housing...
Old Jul 15, 2019 | 03:13 PM
Josephu's Avatar
Josephu
Cut the thermostat off.
Old Jul 15, 2019 | 03:55 PM
GCG's Avatar
GCG
Yes, in fact, if the vehicle speed exceeds 35MPH the PCM turns OFF the fans regardless of the coolant temperature. Air flow through the free-wheeling fans should be enough to keep temperatures within parameters, as long as the system is fine. If there are problems, then the coolant temperature will rise and the fans will NOT come ON unless the car goes below 35MPH.
But that being said, it seems something is wrong with the Low Speed mode that is compounding the problem.
Old Jul 15, 2019 | 04:54 PM
gimp's Avatar
gimp
Yes - if you are driving 40mph, that should provide enough cooling and the fans should be off.
Yes - you should pop the hood and idle it and listen/observe for low speed fans turning on at 226F.
Yes - a thermostat housing with no thermostat is a good thing to try just in case, but you may not want to destroy yours if it's integrated ...
One thing at a time. I think the easiest, least-effort thing is to idle the car with the hood open, keeping track of temperatures, and see if the fans turn on low speed at 226F. (You can also turn the AC on - cold air - and at, I believe, 185F coolant temp, they should cause the fans to start. Someone correct me if that temperature is wrong.)
Another question: what are the oil temps doing? When your coolant gets to 250F, what does the oil temperature read?
Old Feb 4, 2020 | 12:06 PM
greendot's Avatar
greendot
Default Stealing thread re: correct T-stat and pump
Originally Posted by bravo29
Are you sure you have the right thermostat to new water pump? 2 versions out fixed and non-fixed to housing.
I'm searching for this sort of info before posting my question. I recently replaced the water pump on my early build 2002 Z06. I re-used the original T-stat built into the housing.
Problem I have is on the highway the car is running ice cold, like in the 130's. It is not a problem of no coolant at the sensor because I can grab the rad hose and it is cold with no pressure as if the car were actually over heating. Sitting and idling the temp comes up to 210 ish as expected.
So, the old T-stat and housing on a new pump is a problem?
TIA
Old Feb 4, 2020 | 03:30 PM
gimp's Avatar
gimp
If it's running ice-cold, it almost certainly has failed in an open position. You need to get a new thermostat.
Old Feb 4, 2020 | 05:32 PM
greendot's Avatar
greendot
Yeah, that's what I expected but stat is closed when I removed it. need to temp test it to see if it is opening REALLY early, but want to know if there are any issues with mixing old stat that is built into housing with a later pump. Thanks
Upon further investigation, Apparently the old integral stat is shorter than a stat and housing unit so the combo of old integral stat and new pump will not work as it does not stop water flow to build heat. maybe this is a good trick for a track car??
Old Feb 4, 2020 | 09:05 PM
gimp's Avatar
gimp
Hmm. I guess it's possible that fitment is wrong and it's bypassing despite being closed. I'll let someone more knowledgeable answer that.
Old Feb 4, 2020 | 09:49 PM
Ed Ramberger's Avatar
Ed Ramberger
I have been down the pump road and learned a lot. If you still have your old pump and thermostat, check to see if when you install the thermostat into the pump you can feel the bottom disk on the t-stat with the slots or holes in it exert pressure on the lower ledge inside the pump - it compresses the spring slightly.
Then see if your new one has no compression in the new pump - like the disk isn't hitting the ledge. I have seen different size disks on the t-stats, and have seen some with combinations of what should work that I have doubts about. Feel free to PM me. I have seen where the new thermostat disk doesn't touch the surface inside the pump.
Old Feb 5, 2020 | 03:19 PM
greendot's Avatar
greendot
Exactly right. I have found the old integral stat is shorter than a stat and housing unit so the combo of old integral stat and new pump will not work as it does not stop water flow to build heat. maybe this is a good trick for a track car??
Old Feb 6, 2020 | 12:08 PM
  #33
Speedy007's Avatar
Speedy007
Thermostat needs replacing ! Let it run if continues over heat and you know it the spring in the thermostat is opening ! Check the heater as well as you will not have heat ! You will most likely need to drain or replace coolant ! Be a good idea to get a water pump given it’s right there and easy! Fill it up let it recirculate with the heat full blast to remove any air pockets !
