So my code breaker guy says the vehicle speed sensor in the differential is not giving consistent readings; I should replace it, as it's a part of the ABS. However, before I could buy one, another guy mentioned that the ring the sensor reads can go bad also. Anyone else have any experience with this sensor or ring? Your help is appreciated............................. .........Dan
I understood the differential mounted sensor to contribute to the ABS also. But, yes, the speedo seems to work fine. He cleared the code (C1743) and we drove around for a mile or two, then checked again to find that it had reset and was coding again. I agree that the ring has to be pretty bullet proof. Another had suggested checking the connections prior to replacing the sensor, and that's on the calendar for about 2 weeks from now. Thanks for your thoughts!
