Strange AC issue
2002 Z06, ~50k miles, usually driven about once a week. Mods are a mild cam, full exhaust and CAI. All mods have been on for a while with no issues until today. Couldnt find what I was looking for in the search so im hoping someone can shed some light on this. I have not checked for codes yet. Ill try and get to that in the morning.
Have the a/c tested first.. That will be a quick idea of why it isn't working. If the test comes back good and it is not low on pressure, then your tuner will need to adjust some tables in the computer to make it work. I doubt the cam is large enough in your car to mess with the idle though, but it is possible.
If so, it is NOT a pressure issue. The only way to raise pressure in the system (on the high side) or lower it (on the low side) is for the compressor to be running. Simply bumping the engine revs (with the compressor not running) does NOTHING to increase/decrease pressure in the a/c system.
I hope to trouble shot a bit this afternoon and I'll report back. I'll check battery and codes first. Then I'll check pressure just to see what it's at. If I can't narrow it down there then it's likely of to a pro.
I would check system voltage at idle then again at slightly higher rpm (when compressor engages) and see if there is any significant difference (increase) in system voltage.
https://www.corvetteforum.com/forums...m-stumped.html
That fixed it for me.
If it's not the voltage or the pressure I can check with my tuner.
You will need an A/C Manifold Gauges set. Doesn't have to be top-of-the-line and uber expensive. One from Harbor Freight would be fine, or get a free loaner from an auto parts store.
Although not essential, a Thermometer will give you a better idea of the A/C system health. You can get for around 5 bucks:
Pressures vary not only with the RPMs of the engine, as mentioned above, but with humidity and temperature. Don't add refrigerant blindly.
Check both pressures to have an idea of how things are. Take a look at this Post. It has detailed instructions to check/add refrigerant.
-These are the CliffsNotes:
Find the current ambient temperature and humidity. Then, using the chart below, determine your target values for:
- High Pressure
- Low Pressure and
- Center Vent Temp.
Then take your readings. Make sure you take them with (otherwise readings will be affected):
- Engine @ 2000 rpm
- A/C in coldest setting
- Fan at maximum speed
- Both windows down
- Thermometer in center air vent
When adding refrigerant, pay attention to both pressures, otherwise you might end up with the high side sky-high trying to get the low side to the chart's value.
Let us know your findings
