12 volt outlets
Old Jul 17, 2019 | 07:04 PM
Bad Boyz's Avatar
Bad Boyz
Default 12 volt outlets
Good afternoon all, I have a question that I’m sure somebody has had to deal with. Neither one of the 12 volt outlets work in my 04 targa top work. I checked both circuit breakers and they are good. My question is where do I go next? Any help work be greatly appreciate.
Old Jul 18, 2019 | 12:37 AM
Perhaps check and see if there is power to the connector that plugs into the outlet And moving this to C5 Tech.
Old Jul 18, 2019 | 07:42 AM
feeder82's Avatar
feeder82
the electrical connections aren't very secure and have been known to fall off.
Old Jul 18, 2019 | 08:46 AM
tentuna's Avatar
tentuna
You said CB's they are fuses in the footwell, the manual will point to the correct ones.
Old Jul 18, 2019 | 11:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHAT YEAR C5??? It does make a difference!
There are CIRCUIT BREAKERS in the passengers well fuse box. They are ONLY for the power seats and head lights
In my 02 Z here are the circuit breakers positions are #35, #36 & #54,
Everything else uses fuses.
The Cigar lighter fuse is: 7 and the center console 12 VDC outlet fuse is: 1 in the passengers foot well fuse box.
Old Jul 18, 2019 | 06:13 PM
Bad Boyz's Avatar
Bad Boyz
Thank you all for the comments, Mr Curlee its a 04 and I checked both #1 and #7.I will check the connects and see what it may tell me. Again thank you all for your comments.
Old Jul 18, 2019 | 06:19 PM
3sACROWD's Avatar
3sACROWD
I wonder if a previous owner took the radio bezel off and never reconnected them. Pop the traction control panel off and confirm the outlet in the center console is plugged in.
Old Jul 19, 2019 | 10:37 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I did a few mods and had to remove the console. YES, the plug connection at the back of the actual lighter plug can become disconnected easily.
Bill
Old Jul 20, 2019 | 07:33 AM
Bad Boyz's Avatar
Bad Boyz
Thank’s Mr Curlee and 3sACROWN for your help. I pulled the traction control and that outlet was plugged in. I’m going to pull the radio bezel and check the other connection. Again that’s for your help.
To 12 volt outlets
