98 coupe needs computer flashed
Old Jul 26, 2019 | 11:25 AM
Smokinc5's Avatar
Smokinc5
Default 98 coupe needs computer flashed
Hello everyone! I have a 98 coupe that had a new bcm installed and needs to have the computer flashed to read the vin number. Dealerships are not much help, does anyone have a recommendation? From what I understand, it needs to have a tech II to flash the system so the system recognizes itself. I assume a typical tune will not solve this issue correct? I have a code in the dic that shows 58-sdm no comm.
Thanks!
Old Jul 26, 2019 | 12:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why don't you do the HAND SHAKE that will get the two to communicate. Its EASY and FREE:
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
You better have a GOOD battery or put the battery on a charger!
Old Jul 26, 2019 | 01:59 PM
Smokinc5's Avatar
Smokinc5
Thank you Bill. I was not aware of that procedure. I assume you mean to turn accesories on but not start the car right? I have a battery tender that should do the trick. Thanks!
Old Jul 26, 2019 | 04:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I turn it to ON/RUN but YES,, ON/RUN, engine off.
To 98 coupe needs computer flashed
