window woes
Is there a part for just the passenger side or do I need a master? what's a good source? Thanks, Larry
You should try this 1st. Most likely it's just stuck and this will get it back in working order quickly. Copied from a post by LT1SPUD titled "Stuck door window - easy fix!!!!".
Tools required:
1 small pocket screwdriver
1 long necked screwdriver
1 hammer
an assistant (unless you're a three armed mutant)
1st: remove the small cover on the door just down and back of the hand grip with the small screwdriver
cover removed:
next, align long necked screwdriver under the rear hex head bolt as shown:
now, while having the assistant turn the key to the "on" position and then repeatedly pushing the window "down" button, give the big screwdriver a couple of whacks with the hammer......window should roll on down.......
that is all.......
Good luck!!
Grab the plastic accordion in the drivers door jamb that houses the wiring going into the door and wiggle it around a little while trying the window switch. There is a connector near where the wires come out by the dash that sometimes develops a bad connection.
