Throttle Body Options
Old Jul 28, 2019 | 06:14 PM
bonesbrakr's Avatar
bonesbrakr
Default Throttle Body Options
Been looking around at upgrading the intake which of course means a different throttle body. Was wondering if there is anything out there besides an LS2 silver blade throttle body with adapter harness that would work. I see that the gold blades have 2 problems. first is the throttle body opens in the reverse direction. But if the mounting hole spacing is uniform side to side cant the throttle body just be rotated 180 degrees??? Seems there is enough room on the passenger side of the engine for the actuation motor. Second problem seems to be the TPS voltages being off and throwing codes. I can understand seeing this is a 4 year only part that there is limited availability but the prices seem to be way out there. I am surprised no after market companies are making units to accommodate this problem. Since the car SHOULD be tuned after install is this a problem that can be compensated for???
Old Jul 29, 2019 | 12:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Opening in the reverse direction means that it is trying to SHUT when you want it to open. So the GOLD one will not work if you do the proper wiring conversions.
Old Jul 29, 2019 | 03:24 PM
Daniel@Vengeance's Avatar
0Daniel@Vengeance
Former Vendor
NIck Williams has a 102mm option and requires you to send your unit in. Let us know if there is anything we can help you with.
Old Jul 31, 2019 | 06:42 PM
bonesbrakr's Avatar
bonesbrakr
Did more searching and found out the motor in the throttle body is not a PWM pulse width modulation motor but just a simple DC motor. So reversing the polarity will solve the problem of reverse rotation. The other REP codes can be solved by tuning. Also found this post on here from a few years ago.
https://www.corvetteforum.com/forums...y-on-a-c5.html
Have a conversion harness coming in Friday and found a cheap stock LS3 throttle body. Will keep everyone informed to my findings. Tried to get a silver blade and everyone wanted at least $240. While I do not mind spending money on quality parts, I DO mind over paying when a lil knowledge and tinkering can save me 60%.
Old Aug 3, 2019 | 04:06 PM
bonesbrakr's Avatar
bonesbrakr
Nothing to see here.
Old Aug 3, 2019 | 07:39 PM
bonesbrakr's Avatar
bonesbrakr
Old Aug 3, 2019 | 07:50 PM
My Vette Life's Avatar
My Vette Life
Interesting, getting ready to start buying ls3 parts and wouldnt mind trying this.
What year is your c5?
Old Aug 3, 2019 | 08:23 PM
bonesbrakr's Avatar
bonesbrakr
2001 base hatchback LS1 A4
Old Sep 26, 2020 | 12:27 AM
Jacobv1997's Avatar
Jacobv1997
7th Gear
How has this been working for you?
Any codes being thrown?
I have the same harness and am trying to figure out how to set it up to work with a NW102, which is suppose to be the same pinning as a gold LS3 throttle body...
Old Sep 26, 2020 | 08:03 AM
bonesbrakr's Avatar
bonesbrakr
Been working flawlessly. I admit I have no need to go full throttle stop light to stop light and have only done so 3 or 4 times but no codes and flawless mechanical operation since the install and minor adjustments to the tune.
Old Jul 10, 2021 | 03:19 PM
NSFW's Avatar
NSFW
Did you need to swap the motor +/- wires or the TPS signal wires?
Or was it sufficient to just reduce the max throttle opening percentage?
Thanks!
Old Jul 10, 2021 | 07:30 PM
bonesbrakr's Avatar
bonesbrakr
Actually had to switch all 4 wires for the TPS. Swapped the power and gnd and also swapped TPS 1 and TPS 2. I did nothing with the motor wires, left them as is. Also had to drop max rotation to 94%.
I have 3 throttle bodies with harnesses tested working perfect and no one wants to buy any. Guess they want to hope and prey on a silver blade.
Old Aug 7, 2021 | 10:37 PM
SeanyB's Avatar
SeanyB
C5 of Year Finalist (stock) 2019
Default Throttle body and harness
Originally Posted by bonesbrakr;[url=tel:1603712524
1603712524[/url]]Actually had to switch all 4 wires for the TPS. Swapped the power and gnd and also swapped TPS 1 and TPS 2. I did nothing with the motor wires, left them as is. Also had to drop max rotation to 94%.
I am interested, I want to run one of these on my 04 6 speed. Is the 04 wiring the same as yours, if so I will buy one. Currently car is not running with the silver blade TB.
To Throttle Body Options
