Bad knocking/pinging under full load
I bought my first 2001 base C5 three months ago with 28,000 miles. Its now got 34,000 on it. It’s got SLP headers, pipes and short mufflers and I was told by the seller (the mechanic of the owner who died and who is trustworthy) that the heads were ported and polished, but nothing more. (He didn’t do the work.) Has a Hurst shifter. I run only Chevron premium. It runs at 190 degrees consistently. I do notice a slight occasional misfire when idling, kinda like my 72 Ford E350 460 gas.
On last month on a road trip it had the following codes:
P0153 C
P0430 H
U 1000 H
U 1064 H
I cleared them and it’s been running fine, other than the pinging under full load and over 4K rpms.
Occasionally I get the U 1000 H and U 1064 H codes, always after a bit of idling. Like every few hundred miles.
I ran half a tank premium and half a tank of 102 octane at-gas on my trip that seemed to help but didn’t eliminate it, and I didn’t want to push my luck on a long road trip so I didn’t run it over 4,000 rpms.
Where do you guys suggest I begin?
FYI: I named my vette “Fluffy” cuz theirs nothing fluffy about my beast!
PO153 is slow response bank 2 sensor # 1
PO430 catalyst system low efficiency bank 2
U1000 loss of communications
U1064 loss of communications with BCM
The last three are history. PO153 is current and most likely your problem.
This should do the trick
What about tuning on a dyno?
Steve
Steve
You need to do a "fast clean " 1st ---- again with seafoam prior to adding it to the tank----The instuctions are on the can
Best is to dis connect the brake line booster hose and pour the Seafoam into the engine SLOWLY You need to pinch that hose with some vice grip pliers so the opening is smaller ontherwise the engine will die The car will smoke white smoke badly so do it outside That white smoke is the carbon being cleaned out of the combustion chambers and intake
Run the engine until it stops smoking 10-20 minutes
Finally if that does not stop the pinging I am almost sure that your engine has been tuned before and it just has too much timing above 4000 RPM's at WOT Then you would need a simple retune------A dyno tune is not needed as that is normally best suited for a race only applications --- As they only check fuel and spark at WOT in 3rd gear--They don't drive the car nor address any P/T driving thru all the gears at idle-- cruising --- city--- WOT
