Hello All
Old Aug 5, 2019 | 12:52 PM
2build1sic04's Avatar
2build1sic04
8th Gear
Default Hello All
Hey guys,
I've got an 04 c5,lowered,wide body kit,no other upgraded suspension parts that I know of.
The motor has a Texas Speed cam,with,I believe 243 heads,long tube headers going straight back.
The guy I bought the car from has been very tight lipped about motor.
Car currently stutters at idle,will run,but surges and acts like it wants to shut down.
Is it as simple as getting a custom tune,or?
I'm clueless about this.
ANY help is appreciated, how much this would cost,where do I go,what do I look for in a tuner,etc.etc.
Old Aug 5, 2019 | 02:12 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
with a cam the tune is everything !!!!
Old Aug 5, 2019 | 02:54 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
unless there is an obvious mechanical issue, the tune is the place to start...
Old Aug 5, 2019 | 03:03 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Agreed the tune is the place to start. Go check out some of your local speed shops or local Vette clubs and see who they use or recommend as their tuner. Most likely won't be cheap but you don't want cheap anyway when it comes to that. Don't go looking for a guy standing on the street corner with his skirt pulled up and his leg exposed with a laptop....
Old Aug 5, 2019 | 03:06 PM
2build1sic04
8th Gear
Pretty much what I thought.
New to this sooo,
ANY idea's on what this might cost?
Or where I can look for Tuner in California
Old Aug 5, 2019 | 03:12 PM
CinciZ06's Avatar
CinciZ06
I only stand out there on the weekends, so screw you for judging me!
On the serious side, start by going down the old school roads of air, spark, and fuel first. Verify your MAF and Throttle Body is clean by simply cleaning them with the appropriate cleaners. Check your air filter to see if it needs replaced. Next, do you need plugs and wires? And are your coil packs ok (most likely they are fine)? Then, make sure your fuel isn't old, your injectors don't have a gazillion miles on them, and maybe run some techron through the system to see if it helps. The only other things I would think about are maybe throttle positioning sensors and checking codes. As long as your motor is sans any weird noises from the valve train I bet it's a simple fix one way or another.
If all that is good to go, then you probably just have a **** tune and it needs some love from a reputable dyno tuner. A ton of people throw in a cam and try to live with a mail order tune. It's a band aid, and a crappy one at best. Here is a thread regarding tuners in your area.
https://www.corvetteforum.com/forums...ento-area.html
Old Aug 5, 2019 | 03:17 PM
2build1sic04
8th Gear
Aaarrghh!
Other thing about this 04,the only things that are hooked up,are what needs to be,so I'm probably needing to get into computer with?? Simple tuner and???
Or just go to pro?
(Crap)
Old Aug 5, 2019 | 03:18 PM
2build1sic04
8th Gear
Sorry guys,got my hands full
Old Aug 5, 2019 | 03:23 PM
2build1sic04
8th Gear
Thanks to all
Old Aug 5, 2019 | 03:29 PM
CinciZ06's Avatar
CinciZ06
Originally Posted by 2build1sic04
Aaarrghh!
Or just go to pro?
(Crap)
Go to a pro. Consider it mandatory if you don't want to grenade your motor. I re-read your first post, and it honestly describes to the letter a car that has a cam installed and hasn't been tuned! If the seller didn't tell you who tuned it, then it probably wasn't tuned. That information is kind of the first thing thrown out there by sellers, as it should be.
Old Aug 5, 2019 | 03:33 PM
2build1sic04
8th Gear
That's what I've thought all along.
I don't think previous owner had any tune at all.
I'll do some more research on tuner/links ya all gave me and head that way.
Thanks Everyone!!!
Old Aug 5, 2019 | 03:40 PM
mstromquist
Old Aug 5, 2019 | 04:09 PM
friou's Avatar
friou
Find the best tuner available. Don't cheap out on this. You said the seller was "tight lipped" about the motor. That would make me nervous as hell! Sure do hope this all works out for you. Best wishes and good luck!
Old Aug 5, 2019 | 04:13 PM
2build1sic04
8th Gear
The motor is solid.
He was tight lipped due to smog issues.
Thank you...
Old Aug 5, 2019 | 11:51 PM
Moved to C5 Tech.
Old Aug 6, 2019 | 09:55 AM
2build1sic04
8th Gear
Going to check out Force Fed this a.m.
To Hello All
