fuel gauge problem
Old Aug 7, 2019 | 03:58 PM
glbeauchamp's Avatar
glbeauchamp
Default fuel gauge problem
2002 Z06 with 53,000 miles. I was returning home from Elkhart Lake after the IMSA race (what a let down. Ford 1st and 2nd, Corvette 4th and 6th. But I digress). At any rate, I stopped at a store where I spent about 20 minutes. I started the car and drove off, then noticed a "check gauges" light and the fuel gauge was pegged on empty. I knew I had over a 1/4 tank of gas so I kept going. I checked the fuel range option on the DIC and of course it was blank. Shortly the low fuel warning reading came on. Pushing reset didn't do anything. I the fueled up (15 gallons) and the gauge was still on empty, but after about 10 miles it went to full and everything started working again. Don't know if it matters, but it was in the high 80's and raining for part of the trip before I stopped. I put a bottle of Techron in every other tankful. Haven't had a problem since, but haven't driven anywhere either.. Any thoughts on what happened? Thanks in advance.
Old Aug 7, 2019 | 04:38 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
run some Techtron though it, maybe a couple of times (gas tank)
Old Aug 7, 2019 | 04:42 PM
glbeauchamp
Will do, but shouldn't I get it down to less that quarter tank first?
Old Aug 7, 2019 | 05:48 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
yes, ideally !!! problem how will you know when it's at 1/4 ??
Old Aug 7, 2019 | 08:14 PM
glbeauchamp
Lucky guess?
Old Aug 7, 2019 | 09:48 PM
Ed Ramberger's Avatar
Ed Ramberger
Lots of threads on this - try the techron concentrated as mentioned above. Buy two bottles and run them back to back. you can add it, fill the tank completely before parking the car and let it sit in the garage overnight to act on the sending unit.
Old Aug 8, 2019 | 12:18 AM
mmartinez's Avatar
mmartinez
I always use Chevron Premium which has Techron in it, but I still occasionally have problems with the sending units so I toss a Techron total fuel system cleaner, and I did have one instance where it took 5-10 minutes after filling up for the gas gauge to read full. My bad spot on the fuel sending is about half tank, and once it passes the bad spot it works fine.
Old Aug 8, 2019 | 12:47 AM
glbeauchamp
OUr gas choices up here are pretty much limited to Holiday, Kwik Trip, and BP.
Old Aug 9, 2019 | 02:19 PM
Ed Ramberger
BP is good - use Top Tier whenever possible
Old Aug 9, 2019 | 05:07 PM
glbeauchamp
I usually go to Kwik Trip as it is Top Tier. BP used to be common but now are are few and far between
Old Aug 9, 2019 | 05:21 PM
1190405's Avatar
1190405
Had this same issue, despite exclusively using Chevron premium gas. Once my fuel tank gauge randomly began working again, I poured in a bottle of Techron when I had a hair over a 1/2 tank, as instructed by someone on this forum. It fixed the issue. Haven't had a problem since and it has been maybe 1-2 months now.
Old Aug 10, 2019 | 11:48 PM
glbeauchamp
Well, it quit reading again today. This time there was about 1/2 tank. Haven't done anything about it yet but I am fearing it will be replace the sending unit time. I'll probably fill it up tomorrow and see what happens.
Old Aug 12, 2019 | 01:05 AM
1190405's Avatar
1190405
When I did my research about this I found that a faulty sender normally pegs the gauge to 0 once it goes pass the half tank mark...which is what kept happening to me and it seems to you.
Once you randomly get the gauge to start working again with over 1/2 tank of gas, run the car until you are just a hair over a half tank and pour in a large bottle of Techron. I did this as instructed and it fixed the issue for me.
Old Aug 12, 2019 | 11:12 AM
glbeauchamp
Yesterday I added a large bottle of Techron to 1/2 tank, where I know it is at because that's where the gauge stopped working and I only went about 20 more miles. The car is now parked in the garage and I will go start it up and see what happens when I can handle the disappointment of nothing happening. Which reminds me. Another forum member was kind enough to supply instructions on how to replace sending unit, but after reading them it would seem to me that there one one per tank. How to know which one is bad? A utube vid shows how to do the driver's side only.
Old Aug 12, 2019 | 09:25 PM
mmartinez's Avatar
mmartinez
A bad sending unit will set a DTC and it will tell you if it's the right or left sending unit.
Old Aug 12, 2019 | 10:09 PM
glbeauchamp
Just went through DTC The only current code is P1431 Fuel level sensor 2 performance. Anybody know what that means?
Old Aug 13, 2019 | 10:11 AM
mmartinez's Avatar
mmartinez
That code means it is the right or passenger side sending unit, do a internet search to learn how to replace it your self, basically you get it up on jack stands, remove tire, remove access panel. you will have to drain the tank as the sending unit is at the bottom of the tank, hope this helps.
To fuel gauge problem
Old Aug 13, 2019 | 12:03 PM
glbeauchamp
Thanks much. I will give it a try...maybe. Then again, I might farm it out.
Old Aug 13, 2019 | 01:58 PM
v6turbo87's Avatar
v6turbo87
If you put the Techron in with half a tank then there is NONE in the right tank! You need to run the fuel level down to 1/4 or less then dump in 2 bottles of Techron and fill it up.
Now there will be Techron in both tanks to work on both senders. if you can, let the car sit for a few days or longer to allow the Techron to work.
Old Aug 13, 2019 | 02:07 PM
glbeauchamp
I kinda figured the right would be empty after I thought about it. If I siphoned out gas from the filler tube, that would come out of the left tank, correct? But on the other hand, if I put the Techron in and filled it up, wouldn't the gas overflow from the already full (theoretically) left tank go into the empty right tank as the gas is put in from the pump? I am a bit confused on the fuel flow protocol.
