Window control
Old Aug 8, 2019 | 08:45 PM
KJones's Avatar
KJones
Default Window control
Do I assume correctly that both windows are controlled with a relay? If so, where might it be located?
Suggestions anyone?
Old Aug 9, 2019 | 01:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The relay is inside the Door Control Module (DCM) for that door. Its inside the door. You have a LDCM and a RDCM.
What is happening or not happening with your door/ window?
Ther is a relay for the window UP and one for the window DOWN and a relay for lock solenoid.
Old Aug 9, 2019 | 01:45 PM
KJones's Avatar
KJones
Thank you for the response! Several days ago the RH window failed go up or down! Now neither one works! Looks like I am headed in the wrong direction!! (nothing new for an old guy)
Old Aug 9, 2019 | 02:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Call me!! Pm sent!! :-)
Old Aug 9, 2019 | 03:06 PM
KJones's Avatar
KJones
SOLVED (sort of)!!! Pulled the left door panel, unplugged and replugged the clear connector and......VOILA!!!!!! Now we'll see what happens with the right side.......
Thanks again for your help, Sir!!!!!
To Window control
