C1295h
Old Aug 13, 2019 | 03:23 PM
fcable's Avatar
fcable
Default C1295h
Directional signals became intermittent. In trying to assess what was going on, I turned on the flashers. The second I did, the Traction Assist light on the dash came on, and the DIC displayed, "Service Traction Control...". If I turn the ignition off, and turn back on, everything was normal. When I put the scanner on it, it showed C1295 in history, brake light fault. Further troubleshooting revealed that the hazard switch was defective. Replaced the switch thinking this would not only fix the turn signals, but also the C1295. Not so. Turn signals work fine, although, still have the issue with the Traction Assist light coming on if I turn on the hazard switch. Again, if I turn of the ignition, and turn back on, problem goes away. Any ideas....?
