adjust ride height
Old Aug 14, 2019 | 02:45 AM
reshar17's Avatar
reshar17
4th Gear
Default adjust ride height
how do you adjust ride height on C5?
Old Aug 14, 2019 | 06:19 AM
feeder82's Avatar
feeder82
Old Aug 14, 2019 | 08:51 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Keep in mind that ALL C-5s are now OLD cars. Bolts, especially the ones in the front, may not want to turn, and in front, the bolts are housed in a threaded insert, that is bonded to the fiberglass sprint. Get too "muscular" with a stubborn front bolt, and the insert will rip itself loose from the spring, and then you have an "issue" on your hands. In the rear, if the bolts seize up or break, it's not as big an issue, as you can just buy new bolts.
Old Aug 14, 2019 | 09:04 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have to be careful on lowering the car. The suspension travel is already limited and if you slam the suspension down to its lower limits the car WILL hit the limits of suspension travel and unsettle the car if you encounter a bump in the road at higher speeds! ASK ME HOW I KNOW! Its a little unnerving and surprising and can cause you to loose control of the car.
Unless you modify the rebound stops on the shocks and modify any other bump stops. be ready for a good jar if you encounter any bumps in the road.
Old Aug 14, 2019 | 10:12 AM
dskinsler83's Avatar
dskinsler83
So by the video above you are screwing the front bolts all the way out putting MORE pressure on the front leaf and backing the rears all the way to the end to DECREASE pressure on the leaf? Sounds counter intuitive
Old Aug 14, 2019 | 10:14 AM
dskinsler83
Disregard I was picturing the first part of the video in my head ����*♂️
Old Aug 14, 2019 | 10:17 AM
dskinsler83
BUT! I do want to mention that my bolts in the rear are oriented opposite his in the video. The thread is down and the bolt head in on top?
Old Aug 14, 2019 | 12:04 PM
JWM's Avatar
JWM
That ain't right
Old Aug 14, 2019 | 12:31 PM
dskinsler83
Well crap!
Old Oct 14, 2019 | 08:46 PM
YELLO C5's Avatar
YELLO C5
I've been trying to raise my car since I'm scraping everything. Got the driver side done. It was stubborn but the passenger side won't budge. Just broke my 1/4 ratchet trying to break it loose. Sprayed it with BP blaster but where does it actually bind? Is it the spring?
Old Oct 15, 2019 | 08:03 AM
leadfoot4's Avatar
leadfoot4
Either the threaded insert in the spring, the threads on the adjusting bolt, or both, have corroded, and "set up". If you got one side to move, I would think that the other side shouldn't be all that bound up. After all, they're on the same car, driven through the same conditions. You might be able to break the bolt free, by applying some penetrating oil, carefully, on the threads of the bolt, right where the bolt enters the insert, and let it soak in for a couple of days. Then try to "rock" the bolt back and forth, GENTLY, and hope it breaks loose.
Old Oct 15, 2019 | 02:35 PM
69autoXr's Avatar
69autoXr
Did you unload the adjuster before trying to turn it? Block of wood on the spring with floor jack, just enough to unload the adjuster...
Old Oct 16, 2019 | 03:17 PM
YELLO C5's Avatar
YELLO C5
Yes. Always wonder how much unloading is needed, though. I've had enough lift where the jack starts to get unloaded.
I'll try a couple days with penetrating oil. I know heating the spring would be bad but anyone try heating the bolt?
To adjust ride height
