Will i need a new tune?
Old Aug 15, 2019 | 07:53 AM
dmd1998's Avatar
dmd1998
Default Will i need a new tune?
So my 98 is just about full bolt on with a cam. Car is dyno tuned with those mods.. I just got an ls6 intake manifold and plan on installing it. Will I need a new tune just for the mani? or do you guys think it will be okay?
Old Aug 15, 2019 | 09:08 AM
INSTIG8R's Avatar
INSTIG8R
It could probably be ok, but a tune would optimize it and will definitely smooth it back out. You may not need a full blown dyno tune, a street tune would do just fine
Old Aug 15, 2019 | 09:17 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theoretically, YES you will!! In actuality the car will run fine.
Will it run the best it can? NO.
Anytime that you change the air flow of the engine by altering something between the MAF and the MUFFLERS, it does effect the tune. How much it effects the tune, is what is in question.
Do this: Get some data logging/scanning software and look at the LONG TERM FUEL TRIMS (LTFT) and SHORT TERM FUEL TRIMS (STFT). After you change the manifold, re-examine them again. If the LTFT are far from being slightly negative, your tune needs to be adjusted. The part of the tune that will most likely be effected is the Volumetric Efficiency (VE) tables and the Wide Open Throttle (WOT) Fuel Trim AFR.
All of that can be checked without doing a tune. Its called data logging. There are phone APP software products that you can purchase to do this monitoring. If the tune is way off, get a retune to get all the power that's on the table. If it a little off,, just live with it. You will also need a Wide Band AFR meter to check the WOT AFR.
The WOT AFR is where you make all your power. If its very rich or lean, it can severely effect engine performance and longevity.
My 2 cents
Bill
Old Aug 15, 2019 | 09:57 AM
wydopnthrtl's Avatar
wydopnthrtl
I've done some tuning on fords... In the tune there is a place to enter intake volume. A small trick some tuners do (and I did too) is to enter a volume that is 1/2 of the actual volume. This gives a bit better tip in response. (makes the throttle feel slightly more responsive in every part throttle situation)
I even tried toying with the volume calc by changing in small percentages up and down. It didn't make much difference either way.
IMO if the MAF and TB are the exact same parts that were used during your dyno tune.... you'll be ok w/o a tune.
(TB and MAF are "inputs" to the tune so changing those physical parts will require a tune change)
Just make sure there are no leaks after the R&R. Use a smoke machine if possible. Intake manifold leaks (and exhaust leaks) have lead many a DIY'er down false paths of repair for many yrs.
Old Aug 15, 2019 | 10:34 AM
dmd1998's Avatar
dmd1998
My 2 cents
Bill
sweet thank you for the info
Old Aug 15, 2019 | 10:36 AM
dmd1998's Avatar
dmd1998
That's what I was thinking.. And thanks ill be sure to check for leaks after the install. I appreciate the response
To Will i need a new tune?
